383 hatch
- Jun 14, 2005
- 3,922
- 67
- 48
- Age
- 41
- Location
- Cowes, Phillip Island
- VG Ute 5.0,Torana hatch 383,WB Ute 5.0,VR stato5.0
As the title says, i am having a shed clear out to fund a new engine. All parts are located in Phillip Island, Victoria. Will post smaller parts if required.
This is what i have:
VN V8 engine loom & ECU $200
VN-VS V8 ignition module (working order) $120 SOLD
V8 ignition coil (square type) $80
Banana manifold-Good condition, no corrosion $80
V8 Throttle body (complete) $100
VN V8 spike/A9L conrods with good stock pistons (set) $250 SOLD PENDING PAYMENT
VN V8 K frame & steering rack in good condition (needs one boot replaced but i will replace that as part of the price $200
VN V8 heads, pulled off good running engine, i have just replaced the valve stem seals as i was going to use them $300
304 standard bore block, needs bore & hone $150 SOLD PENDING PAYMENT
304 crank, needs regrind $80 SOLD PENDING PAYMENT
VN-VS 3.91:1 Diff gears $200 SOLD PENDING PAYMENT
VN V8 airbox (stock) $30
VS V8 CAI set up with modded lower air box (modified to suit VN) $30 SOLD
VN-VS electric rear window reg (good working order) $30
VN-VS rear electric window switch $30 SOLD
VN-VS L/H electric mirror (black) $30.
I will also have a set of VN-VS 5 litre pacemaker extractors with Y piece that will be for sale probably early next year if anyone is interested, however if anyone wants them sooner i will be willing to remove them earlier. The drivers one has had a crack welded up, other than that all in good condition. Chasing $250 SOLD
Thats about all i have for the time being, however i do have some various engine mounts/plates, alternator bracket and various other engine ancilleries to suit VN V8
Will post pics if anyone requires them.
Cheers :thumbsup:
Cheers :thumbsup:
