trying too put new pics up n the uploader for my pics is full how do i empty it ?
cheers
http://forums.justcommodores.com.au/...ditattachments
Hopefully that works, then simply select / delete attachments no longer required or use photobucket or something else, there's a few how to guides on that somewhere in the feedback section other members have kindly put together.
thankswilll go try
y not use photobucket or similiar hosting website for your pics?
photobucket is the easiest option IMO.
I can only post 2 pic,s at a time & then when I clear them it also clears them the tread I put them in,,dont know how to use photo bucket,, this is a very hard site to post pic,s
It isn't that difficult, according to the stats 95,580 have attachments have been put up on the site.
A lot would be to do with the fact images are generally oversize, for a standard member as yourself the maximum limit is 700KB.
Now having said that geez I must have set this years and years ago, I have just increased this to 10MB.
Registered Full - ie account is minimum 3 months old and 20 technical section posts has been increased to 25MB and Donating members double that again.
Maximum Images/Videos Per Post is already set to 50 so that plenty so I suspect you were simply hitting this limit.
Give that a crack, I suspect that might be better.
If you clear the attachments then they would be removed but given how restrictive attachments were setup previously from years back I can see why.
vBulletin changed the upload attachments which I think is crap, there's nothing wrong with a simple upload and away it goes instead of all this drag and drop crap.
Thanks guys for bringing this up but hopefully this corrects a few issues!
