Results 1 to 16 of 16
Thread: Model dates in the fault code section are wrong
    mixin is offline Ol' fart, young heart!
    May 2004
    Country Vic
    Default Model dates in the fault code section are wrong
    The fault code section has some misleading details that should be cleared up to prevent any identification mishaps...
    This is how it is now:
    Computer Fault Codes
    VL Commodore 1986 - 1988
    VN Commodore V6 1988 - 1991
    VN Commodore V8 1988 - 1991
    VP Commodore V6 1992 - 1994
    VP Commodore V8 1992 - 1994
    VR Commodore V6 1994 - 1996
    VR Commodore V8 1994 - 1996
    VS Commodore V6 1996 - 1998
    VS Commodore V8 1996 - 1998
    VT Commodore V6 1998 - 2000
    VT Commodore V8 1998 - 2000
    VX Commodore V6 2000 - 2002
    VX Commodore V8 2000 - 2002
    VY Commodore V6 2002 - 2004 - Coming Soon
    VY Commodore V8 2002 - 2004 - Coming Soon
    And this is how it should be, with the corrections marked in red:
    VN Commodore V8 1989 - 1991
    VP Commodore V6 1991 - 1993
    VP Commodore V8 1991 - 1993
    VR Commodore V6 1993 - 1995
    VR Commodore V8 1993 - 1995
    VS Commodore V6 1995 - 1997
    VS Commodore V8 1995 - 1997
    There is the VSIII ute & statesman derivatives to fit in this gap.
    VT Commodore V6 1997 - 2000
    VT Commodore V8 1997 - 1999 (Holden 5L)
    VT Commodore V8 1999 - 2000 (Gen3 5.7L)
    VE Berlina International II
    Nov 2003
    Also in checking VN Fault codes it should read paper clip, but i says "Paper" towards the end.
    Thats all right, thats ok, I drive a commodore anyway!!!!
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Quote Originally Posted by mixin
    Wrong... my VL is a 1989
    EDIT: wrong again, as my understanding is that the VN was first produced in 88, as the origional table suggests. And another point, the VSIII has the same engine and transmission packs as the VSI and VSII, thus 1995 - 1997 cover it.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    Nov 2003
    Quote Originally Posted by jetspin_vl
    yep there are 88 VNS
    May 2004
    Country Vic
    The VL ceased production in june/july 1988, and the VN commenced in August 88. No models run concurently!
    No, the VSIII V8 is the roller cammed model as fitted to the VT , not the VS 1 & 2.
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    Well you got me on the roller cam bit, but the VN began production in 1988, and my own VL is a 1989 model, so go figure.
    I know what your getting at, and yes you are right but remember that there are some exceptions!!
    May 2004
    Country Vic
    There were no VLs made in 1989 whatsoever, so there is no chance of it being an '89 model.
    The only slight chance of something like that is if it may have been first registered in 1989.
    Definately no VLs were built after August 1988 when the Elizabeth production line was changed over to VN assembly, and Dandenong was closed.
    What does the model year letter code say on the body tag? Bet it notes an '87 or '88 model year code. The '88 model year code was also shared with August '88 VNs, but from Sept 1 1988 the letter changed to the '89 model year code (follows the GM US tradition).
    VS Acclaim Series II
    Oct 2003
    North Gold Coast
    I would have to say that perhaps the reason jetspin has an 89 Model VL might be something to do with him being in NZ but that said ..... they would not make both VN and VL and sell them at the same time so i dont know what the go is there
    What do you want to drink today?
    Ride: VS Acclaim Series 2 + K&n Air Filter
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    The VL VIN number, assigned by Holden as per a coding schedule, uses the letters 'F' 'G' and 'H' to represent the build years of 1986, 1987, and 1988.
    The letter in my car, is 'M'
    Date of first purchase/regn = 2 May, 1989 with an odometer reading of 15km.
    If your not convinced, I'll photograph the bloody thing for you.
    EDIT: Sorry mate I don't mean to sound cranky, but you can't argue with the VIN. Not that I have any idea exactly what M is, I presume it's 89.
    May 2004
    Country Vic
    Quote Originally Posted by Gobbles
    That is right, VL & VN were never made together. There were quite a few VLs left to flog off at runout time though, and there were some amazing deals to be had. An ex workmate of mine bought one in the January holidays of 1989 for $7K less than the VN he was looking at, and it's a far better car than any early VN.....
    The VL was only assembled in 2 locations: Victoria & South Oz. I worked at the old plant removing parts of the production line when the VL was finished & the plant was closed down. If it has a J as the plant code letter, then it must have magically appeared from no-where, as there was nothing left to build it from!
    The SA plant had the production line rejigged to suit the VN. This was completed by Mid '88, so no VLs could have been made there after then.
    Where the VL was made is denoted by a J or an L like this:
    8X198GL200342L
    An L there denotes South Oz assembled, and a J denotes Victorian assembled.
    The letter at the end of the serial number stamped on the strut tower, as well as at the end of the body number on the build plate also denotes what plant. M (Melbourne) = Victoria, A (Adelaide) = South Oz.
    Yes, that's quite right, but I'll explain model year a bit better:
    The model year runs from september 1 of the year before until August 31 of that year.
    Ie, a 1987 model year (code=G) is from 01/09/86 to 31/08/87.
    The letter "I" s never used in the year/date codes to minimise confusion with the number 1
    So we know '86 is F, '87 is G, '88 is H.
    Now "I "is not used, so theoretically, the next code for the '89 model year would be J.
    BUT!
    This is where it jumps the gun:
    For the VN, the model year letter was moved up early. The '88 model year just for the VN is J (ran for less than one month in August '88).
    After that, they continued consecutively: '89 is K, '90 is L, '91 is M etc etc.
    M is a 1991 year code - ie from 01/09/90 to 31/08/91.
    Assuming you have a code like this:
    8X198GL200342L, then the G is in the position of the model year.
    If it was an M there it would make it a 1991 model!
    I reckon it is a 1988 model, denoted by a H which can somewhat like an M because the tag is painted over in the factory, and the paint can gather on the crossbar of ther letter "H".
    By the time it was shipped to NZ, and with the slow sales of VLs thanks to the well publicised VN release, it is not out of the question for it to have taken until May the following year to sell it.
    To be 100% sure, you'd have to drill out the rivets, remove the plate & look carefully from behind - I guarantee it will be a H.
    If you drill out the rivets & take the plate off & photograph it - and I'm talking a virgin photo here, no "digital enhancements" allowed, and it really is an M, then I will put my money where my mouth is & give you $100.
    Mix'
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    Heh, you've proved yourself worthy. I havn't been back out to look at it yet coz its too dark now, so I'll take what you've said to heart and have another look in the morning to see if I can convince myself it H not M.
    I can also see that being a problem, as all the regn' details denote the letter to be M. Insurance could screw me over if they wanted to, and theoretically Im driving an unregestered car using plates for a car that doesn't exist!!
    Hmm, perhaps I'd better have a REAL good look at this, its the sort of thing they would check. And just my luck if I have a crash and enough paint was taken off the area to reveal the letter H.
    This has been very interesting indeed....
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    In another strange twist, the plant code on my VIN is... K!! According to my owners manual, and your good self, there were only two production lines in Melbourne and Adalade, codes L & J.
    This just got real confusing. Anyone know of a secret underground VL production line?! Surley there were no NZ assembled ones, every source I have and every person I have spoken to uses the words 'export 2 litre model'
    For the mystery solvers amongst us, here's the cars VIN as recorded in the owners manual and as I read it on the VIN plate...
    8L197MK713665L
    As I read it, this makes it a GM Holden Commodore Berlina 6 window sedan with 2.0 EFI engine, built in 1991 at an unknown plant, serial number 13665, and model code VL.
    Talk about wacky.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    ok, ill change those code details, but what is your sorce? that way i double check
    i am the god of britany spears womanizer on just dance on the wii
    Sep 2005
    tomato tomato, lets call the whole thing a cuccumber? lol
    look at your 'booty tag' i mean body bag. Look! WOW now you know when your car was manufactured.
  15. #15
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    post pics of the VIN plate and the body plate, sounds likesomething dodge going on here
  16. #16
    Julie's Avatar
    Julie is offline moderator- for now anyway
    Blown VT Calais 355 + SC VY V6
    Mar 2004
    Western Sydney, NSW
    I wouldn't be too worried fellas, that post is 2 years old
  1. Fault Code 19
    By Apeman69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2007, 05:11 PM
  2. fault code 31?
    By metalskin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2006, 06:29 PM
  3. ECU Fault code
    By TigerVX in forum Electrical Wiring / Questions
    Last Post: 26-07-2005, 05:55 PM
  4. Fault Code Help
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2005, 07:43 PM
