Results 1 to 15 of 15
Thread: JC wont work!!!!
    VE II SV6 Sportwagon
    Sep 2005
    Angry JC wont work!!!!
    ok i've been able to get on JC since its been back online at skool, but not at home, i still only get the msg sayin it will b back shortly, its says sum servers arnt up or sumsht? im on bigpond, any1 else on bigpond able to get on? or wat can i do to get on,
    i need to get on at home!!!!! lol
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    try clearing cookies etc with IE or release and renew your ip.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    Sep 2005
    im on a mac, so im using safari, and ive cleared all tha cookies n all that
    Sep 2005
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    you will be without jc for atleast a month if you are on big-pond. big-pond dont update all that often, they do a update of all name servers once amonth. as a result you wotn get it for a month. there is nothing you can do, it's a crappy service provided by telstra.
    i am the god of britany spears womanizer on just dance on the wii
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    Not sure about the crapintosh but PC you can do the following:
    Start > Run > Type in CMD and hit enter
    In the command prompt type in the following:
    edit c:\windows\system32\drivers\etc\hosts and hit enter
    At the very bottom you will see 127.0.0.1 localhost
    From the next line type in the following:
    122.201.85.105 justcommodores.com.au
    122.201.85.105 Just Commodores - For All Your Holden Commodore Needs
    122.201.85.105 forums.justcommodores.com.au
    After entering the IP above hit tab once then type the domain.
    Save and edit the above.
    Due to the SEO setup on JC the 2nd option should be just the www address.
    On the mac I would imagine you can do it via terminal, in linux it's something edit vi /etc/hosts and the same principle as the above.
    Subaru Liberty
    Feb 2007
    Quote Originally Posted by Garth View Post
    Is this for all Telstra customers (dial up, IDSN, adsl, adsl2, adsl2+, and cable)? I have Telstra cable, it is all works perfectly from here. Melbourne location.
    Darren's Avatar
    Feb 2003
    This would depend on which DNS server you utilise, if my memory serves me correct each state uses something different.
    hightekhosting's Avatar
    hightekhosting is offline had no choice
    VS Acclaim S2 V6
    Aug 2007
    Wagga Wagga, NSW
    That is correct Darren.
    JC Members,
    If you are on Bigpond ADSL in NSW, you should of already received DNS updates.
    If you are in NSW and are still having issues, try resetting your modem.
    The easiest way to be sure you get a clean connection and refresh is:
    1) Turn off your ADSL modem for 15 minutes - this is because telstra have an idle timeout refresh period (though they dont tell you this)
    2) Turn your modem back on after 15 minutes and give it 5 mins to reconnect.
    3) Clear cookies, history etc on your pc
    4) Reboot your computer
    If this does not work, then it still may be Telstra, however, in an office I do IT management for they have Telstra ADSL and they have received the DNS update, but they run an internal DNS server too, so it feeds live caching.
    If you run into issues, then let me know.
    Regards,
    Dale Evans
    Manager
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    The info that Darren posted is waht i used and an now here.
    Thats a dial up connection in Adelaide tho (were a little behind tho, colour TV is coming out soon)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VP Executive R-spec
    Jan 2005
    I'm on bigpond adsl and it's been workign here for ages allready but it does not work on bigpond ISDN still as of yesterday
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    im on telstra adsl in nsw and i got on this site pretty well when it started up again, there were like 5 or so members online
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Sep 2005
    i stillll cant get on at home
    im only on fkn bigpond dial-up, but farkkkk, i wana get on, atm im tryin to post this without tha teacher bustin me n kikin me out :P
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by T-ROY View Post
    Check ur cookies dude, might need a cleanup..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  15. #15
    Sep 2005
    its ok its bak up now, every1 can relax :P
    bout time, im wraped now
  1. Starter too hot - wont work?
    By KiwiKommy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-11-2007, 07:53 PM
  2. headlights wont work
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 09:22 PM
  3. indicators in vr wont work
    By Burnout_bro in forum Electrical Wiring / Questions
    Last Post: 07-05-2007, 05:19 PM
  4. rca leads wont work
    By V-ahhh in forum Car Audio
    Last Post: 09-10-2005, 03:19 PM
  5. sub wont work
    By vpwgn in forum Car Audio
    Last Post: 11-04-2005, 09:10 PM
