I can log in fine, access my acount info but I can't veiw posts I've made when I search or find the threads I've started.
When you see a car that's BLOWN it's refering to the budget.
If they were made between April and end of august they will be non existant.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Theodor Seuss Geisel
I have found refreshing the page everytime I open something helps but I still can't view my threads at all, even the ones before april. I try to search my threads and it comes up that I'm not logged in even if I am and when I try to log in it comes up with the not logged in page.
I would agree with hakhawk.
Clean your cache and temporary internet files.
Some users have reported that doing this has solved their issues.
Also, check that your cookie settings and antivirus/antispyware software is not blocking the justcommoodores.com.au cookie.
Regards,
Dale Evans
Manager
Tried clearing the temp files and still no joy, antivirus doesn't seem to be blocking the jc froum cookie either???
Also found when I log in it comes up with the original log in page after the redirection
ive found(even before the crash), that sometimes after logging in at the main page, then going into the forum, asks to log in again. but after logging in the second time, its fine. but its a rarity, as i rarely log out
I always log out and now it doesn't seem to matter how many times I log in I'm still redirected to log in once again until I refresh the page. If that is how it will have to be then I'll just have to keep doing that.
fmlycar,
I will look further into this issue for you.
So far, I am only aware of you having the issue, however, just to be sure, I will take some notes and refer further with you once I have done some further investigation.
Regards,
Dale Evans
Manager
Thanks heaps
I have never seen this problem previously but certainly sounds 'cookie' related to me.
If you hit 'remember me' just before hitting login does that make any difference?
I just gave that a go and doesn't seem to make much difference. I don't have the log in issue that way but my newest posts still won't show up until I refresh the page.
Just read a few other posts on the subject, and looks like a telstra issue. Who would of guessed.
I'm having an issue at the moment where I can log in at work, but not home.
Cleaned cache and temporary internet files.
Checked DNS setting and all are fine.
Checked blacklist on modem, firefox, IE and AV. all fine.
From home I get this.
Tracing route to forums.justcommodores.com.au [72.55.153.74]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway [192.168.1.254]
2 13 ms 12 ms 13 ms 202-154-95-181.people.net.au [202.154.95.181]
3 12 ms 12 ms 13 ms MEL-CTY-BDR-B-g-0-2.people.net.au [218.214.17.25
1]
4 14 ms 12 ms 13 ms 302-ge0-0-0.GW4.MEL1.ALTER.NET [203.166.42.121]
5 13 ms 12 ms 14 ms 324.at-3-0-0.XR1.MEL1.ALTER.NET [210.80.32.153]
6 23 ms 25 ms 25 ms so-0-1-0.XT2.SYD2.ALTER.NET [210.80.33.105]
7 180 ms 179 ms 181 ms 0.so-5-2-0.IR1.SAC2.Alter.Net [210.80.48.230]
8 180 ms 181 ms 179 ms 0.so-2-0-0.IL1.SAC1.ALTER.NET [152.63.48.33]
9 183 ms 188 ms 184 ms 0.so-5-1-0.XT1.SCL2.ALTER.NET [152.63.56.150]
10 187 ms 187 ms 185 ms 0.so-6-0-0.BR1.SCL2.ALTER.NET [152.63.57.49]
11 189 ms 185 ms 186 ms if-14-0.core1.SQN-SanJose.teleglobe.net [66.198.
97.25]
12 188 ms 191 ms 190 ms if-4-0-0.core3.SQN-SanJose.teleglobe.net [66.198
.97.30]
13 189 ms 189 ms 191 ms if-9-0-0.mcore4.PDI-PaloAlto.teleglobe.net [216.
6.33.6]
14 265 ms 268 ms 267 ms if-4-0.mcore4.NQT-NewYork.teleglobe.net [216.6.8
6.14]
15 266 ms 270 ms 271 ms if-1-0.mcore3.MTT-Montreal.teleglobe.net [216.6.
87.22]
16 268 ms 268 ms 267 ms Vlan2.msfc2.MTT-Montreal.teleglobe.net [207.45.2
21.135]
17 262 ms 262 ms 262 ms g6-2.mtl-hd-core01.teleglobe.iweb.ca [66.198.80.
58]
18 266 ms 252 ms 252 ms tg8-1.v999.mtl-cl-core04.iweb.ca [209.172.58.149
19 255 ms 256 ms 256 ms ip-72-55-153-74.static.privatedns.com [72.55.153
.74]
Trace complete.
and from work I get this.
Tracing route to forums.justcommodores.com.au [122.201.85.105]
1 <10 ms <10 ms <10 ms 192.168.30.254
2 10 ms 20 ms 10 ms 10.225.16.1
3 270 ms 261 ms 270 ms justcau.justcommodores.com.au [122.201.85.105]
Trace complete.
thought id just hi-jack this thread instead of starting a whole new one to mention something ive noticed happening only just recently.
whenever i try to get into my user cp using the section selector thing (lol, dunno what its called, the thing down the bottom of the page to skip to different sections) its comes back with a "http 404 not found" message...but when i use to user cp link at the top of the page transport bar its goes to it fine.
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
I have never noticed that before, not that I ever use it.
I'll have a look at that tonight or tomorrow as I continue to plug away as some things are quite right.
cheers for fixing that darren, i noticed tonight its working fine![]()
