Sorry to bother anyone, but its a small issue I have posted a few times today on a few threads and none of my posts are being counted.
I only joined today...so i don't know if that has anything to do with it.
Thanks in advance Chris.
Oh yeah i forgot I downloaded my profile picture, on my user CP it says no worries...then when I go save changes it says problems with file or something....Could I please get some help with this one too.
Sorry to be nusance.
they will add up dont worry mate
DVLHSV Stage 2 is Now in Operation
My VYII Clubsport http://forums.justcommodores.com.au/...clubsport.html
Posts only count in the technical sections of the forum.
The pub, My Ride etc. do not count towards your post count.
How about going from 18 posts back to 17?
the above advise is true.
Citric, did you have any luck with your pic? make it smaller and see what happens.
Check out my ride.
http://forums.justcommodores.com.au/...s-my-cars.html
IF YOU WANT MORE INCHES THEN STROKE IT
You still having trouble with your picture?
You can email the picture to me if you like, and I'll resize it, and check it's in an appropriate format (jpg, gif, png), and convert it if it's not, etc.
Otherwise, if you want to try to reduce the file size yourself, probably the first step is to save it as a jpeg file (.jpg), if it's not already. This will hopefully reduce the file size (ie: kilobytes, megabytes etc.).
The other possible issue, resizing the actual dimensions of the image as it appears on screen, will be slightly more involved.
Obviously both these changes would require some kind of software which can open/save, and/or edit images. (ie: photoshop, or one of the free alternatives).
Cheers, Alex.
Check out my ride.
