Ace_VP
Hi guys, got a new bonnet and wing for my commodore, had a big dent on the very corner of the wing and then the bonnet next to the wing. Didnt want to stuff around bashing the dent out and then priming and respraying that one section cause the paint isnt the best so it would stand out like dogs nuts. So i picked up a bonnet in perfect condition and a wing to match.
Went down to auto one today and got some paint matched up to the colour code in 2 pressure packs. I havent done much in the way of automotive body work repairs before so im keen to give it a crack. Got some primer, wax and grease remover and some thinners to give everything a final wipe over with.
I got a scoth pad and rubbed back the wing and sanded the odd rock chip until it was smooth and back to bare metal in a decent circle around where the chip was. The paint on the wing and bonnet is in really good condition.
Then i did the bonnet, it had some rock chips on the forward facing edge and the clear coat had peeled back in one small section. Rubbed this right back, gave the whole bonnet a really good rub over with some sand paper.
Degreased both panels, then rubbed back with a clean rag and some thinners. Got it nice and smooth. I gave both panels a coat with grey primer, they came up pretty good i think.
Tomorrow im going to give them both some top coats, taking my time and doing nice even thin coats. From my experience painting other things with spray cans trying to pile to much on in one go doesnt go well.
My question is what should I do between coats? I will let the paint dry between coats as per the instructions but do i give it a light rub back with some fine wet and dry (1200 grit) I only rub it back at the end.
Then, i doubt i will get this far tomorrow, i want to take my time, but when i get to clear coat what do i do to the paint before the clear goes on? Just another light rub back?
Thanks in advance. matt
