where to get paint spray cans filled?
lepht93
Well, you're wrong.
Eastern Melbourne
VP Commodore Executive
Hi,
My car was professionaly resprayed about 4 weeks ago now and I have about 1 or 2 litres of the colour left (thinners havent been added) just sitting in a can in my shed. Some parts of the car id like to touch up with a brush, but for most of the things i need to spray now (a door jamb, new grille) i need the paint put in a can, can anybody reccomend a place who do it and how much it costs?
Also, its a custom colour, so I do have a paint code of the car but the paint i have has had some tinters and pearl added to it, so i cant substitute.
Thanks
hakhawk
smooth moderator
Staff member
most autobarn stores can put custom mixed paint(usually their own) into a pressure pack. drop in and ask your local store, just let them know it IS a custom mix. they retail for $30, they might do it cheaper using your paint. otherwise, you can buy a little kit that has a jar for paint, nozzle and replaceable pressure packs. pour your paint into jar, spray. never tried one though.
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Yeah, My local Auto 1 store sells all that sort of stuff, or can order it in..
Since it is a custom mix, as hakky said, tell them its custom and you have some left over
lepht93
Well, you're wrong.
Eastern Melbourne
do they add the thinners to the mix? because my mate who painted the car said if i add thinners to the stuff i have left over, i have 2 days to use it and then its off.
hakhawk
smooth moderator
Staff member
the spray cans have thinners and aerosol in them, all thats added is the paint, shake the can and spray it, done.
VKCOMMO
Springwood, NSW
Dont forget primer
lepht93
Well, you're wrong.
Eastern Melbourne
thought primer was separate? Then again friend said screw priming the door jamb coz it'll rarely see the light of day anyway ha. Bad news for my door spats though, used rape tape to hold them against the door while the urethane dried, went to remove the tape, ripped the paint right off them. Seems paint doesn't bond with fibreglass very well
vk.jonno
south east
Vk commodore, hq one tonner, hj ute,
Dont forget primer
Should only need to prime if itd
A) baremetal
B) bogged
Or C) a completely darker/diffent color
In your case you probably won't need to prime
lepht93
Well, you're wrong.
Eastern Melbourne
I'll be painting the inside of my door where it sits in the jamb coz it's got White paint (door off a VS), primer needed?
vk.jonno
south east
just wet sand it till its smooth
