Results 1 to 3 of 3
Thread: Painting chrome
    VY 3.8
    Nov 2010
    Maroochydore
    Default Painting chrome
    Is it possible to paint chrome wheels gloss black? If so what's involved?
    VN SS
    Mar 2011
    Auckland, NZ
    Can be done, however the prep work is crucial to make sure the paint stays attached to the chrome plating.
    You'll need to scuff the chrome up so there is NO shine left, 320 grit should do it but 240 works well on orbital/machine sanding etc.
    Use a good hi build primer, guide coat and rub back with 320.
    Then paint with your preffered gloss black, I'd go 2k unless you want a metallic in it as then there's no clear coat to worry about with brake dust etc.
    Faynt11's Avatar
    Faynt11 is offline Feeder of Trolls
    07' VE SV6 Ute
    Jul 2008
    ^^ +1 make sure it's a self etching primer.
  1. Replies: 5
    Last Post: 07-08-2010, 09:08 AM
  2. painting over chrome
    By mightyredvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2009, 09:20 AM
