how would i go about painting the plenum on my 05 vz executive? is it hard to take off and what would be needed to clean it up properly so the paint would stick to it. any help would be great thanx.
heres a pic of wat iv'e done so far. i want to paint the plenum black.
You would need to use heat resistant paint
i know i would have to use heat resistant paint. how easy/hard is it to take the plenum off? and do i have to be carefull of anything while its off or while putting it back on?
its a 10 min job, just ensure you remove all the hoses and plugs, also you will need gasket goo for the Throttle body when you remove it
Life starts at 200km/h
ok then. thanx for that.![]()
use prepsol before painting too!
You don't need heat proof paint, preperation is key though. Why not go to a wreckers and see if they will swap for a black one
or go to a wreckers. get a 2nd hand one.
do the work to it so you can take your time.
and when its done change it over onto your car?
also post up to let us know how you go.
