Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Boostedn14
Thread: Mixed answers from google whats the right method
    vy ss
    Jul 2010
    moree
    Talking Mixed answers from google whats the right method
    I have been doing some resreach using google and just when i think im ready to paint i read something different?
    i just brought a new bodykit its in a gel coat i was going to do the following
    1. sand the new kit with wet and dry using 400grit paper
    2. apply the primer
    3.sand primer using wet and dry 800 grit paper
    4. spray the kit with colour wait 1 hr after the last coat of colour, than apply the clear
    5. after drying for 24hrs either polish it or if its rough colour sand using 2000 grit paper than polish
    i dont know if im doing it right but that what my plans were till i read the following on google
    1. sand the new kit with 1000 grit wet and dry
    2 spray on the primer
    3. when primer is dry sand with wet and dry 200 grit paper
    4. apply colour than half hour after the last colour coat apply clear coat
    5. polish
    can anyone give me the right method including what grade paper to use and when.im using 2 pac paint and its a metallic grey colour and the kit is fibreglass . i will be doing it in my shed at home.
    i know i need to leave between 10 - 15 min flash time between coats. but how long after i finish applying the colour do i apply the clear coat?
    any help would be great
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    sanding the hi-fill with 2000 would be a bit of a [insert naughty word] really
    method 1 is the way i usually do it, with a couple of differences.
    1 give the hi-fill as long as you can possible give to dry. so a week or more if possible. stick as much heat on it as you can, i.e. leave it in the sun everyday, in front of a heater or something to cure it properley so it doesnt shrink later.
    2. you can hit the clear shortly after the first coat. i wouldnt wait longer than an hour. usually around 30 mins. but i guess it will depend on how thick you do it. i cleared the inside of my boot about 15 mins after base colour and it came out fantastic.
    3. wet sand the hi-fill back
    VN
    Feb 2011
    Wide bay
    320 your gel coat
    Hi fill - 2 solid coats
    Wait a day or 2
    500 down on sander/interface pad
    prepsol
    tack rag with blowdown
    blow first colour over - flash off 10 minutes
    blow second coat over wait 10 minutes
    Drop coat - wait 10 minutes
    Clear - wait 15 minutes
    Clear - Done.
    then sand and buff the next day if its dry enough.
    VN
    Feb 2011
    Wide bay
    Theres a million different way to do it, the above is how i would do it, has never given me grief, don't get any scratch marks, no sink back and looks good. I use this same method day in/ day out.
    wagon
    Nov 2006
    South East Vic
    vy ss
    Jul 2010
    moree
    Default Dump question?
    might seem like a dumb question but should i strain my basecoat and clear, my basecoat is a metallic colour if i do what "grade" strainer should i use?
    VN
    Feb 2011
    Wide bay
    i think we use a 120/200 micron filter, but you should strain all your colours and clears.
    But just get some off the shelf paint strainers, to get the bigger lumps of shit outta your paint.
  1. Whats best method for removing external door moulds? HELP?
    By timbra_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2011, 07:49 PM
  2. lsd into vx series 2 acclaim what is the best method?
    By goofyduude in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2009, 06:49 PM
  3. best method to clean your seats?
    By betts in forum General
    Last Post: 14-11-2006, 09:52 PM
  4. air intake... BEST method
    By i_want_kw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-12-2005, 07:45 PM
