Results 1 to 5 of 5
Thread: painting around door opennings under bonnet and boot of 88 vn
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default painting around door opennings under bonnet and boot of 88 vn
    Just wondered what isolator/primer surfacer to use to repaint these areas that will be 2k primed and finally top coated in a different colour from original in 2 pak...everything external (bonnet boot roof outside panels)is going back to bare metal but just wondered if you can get away with just a isolator over the original paint in these areas ? Ive read scansealer could be used? Is it normal practise to clearcoat these areas after applying the colour?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VS Executive S2
    Jul 2010
    what colour are you doing it? are you doing this yourself? if so are you removing the doors?
    the steps i would take if i were doing this on my own car
    • Remove the doors (need a door pin removal tool) I'd remove them so you can clean and scuff the surface thouroughly
    • clean surface with wax and grease remover until clean
    • give good scuff with red scotch-brite
    • rub out chips/scratches with 400P wet and dry
    • becarful with the rub throughs because if your worried about it reacting, this is where it will do it
    • clean and dry area, then wipe on and off wax&grease remover again (using clean rags)
    • isolator can be used here, avoid heavy coats (this will stop reacting between paint products) [then allow drying time] OR PPG scansealer can also be used, it also acts as a light adhesion promoter [2 meadium wet coats then allow drying time]
    • then use your 2k primer over that, and it shouldn't react
    hope i havn't forgot anything and that this is actually helpful
    VS Executive S2
    Jul 2010
    and it's only not normal to apply a clearcoat if its a direct gloss colour.
    Nov 2003
    northside brisbane
    thanks for the replies and the colour is hothouse green which of course is a metallic...doors will come off and interior will be stripped...drama is the car has been resprayed before I got it with acrylic over the original colour so theres plenty of paint on the car before I start.
    VS Executive S2
    Jul 2010
    as long as you dont apply heavy coats of any product that has a substantial amount of thinners in it you should be ok. i wouldn't worry about it having too much material either, it sounds like it'll be ok
  1. [NSW] FS: VT Headlights $50- bonnet protectors, door handles & door mirrors
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 19-06-2010, 09:28 PM
  2. Boot lid painting
    By craigvk in forum General
    Last Post: 03-07-2006, 01:29 AM
  3. Painting Boot Garnish
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2006, 12:47 PM
  4. Painting Bonnet Scoop
    By Owen in forum General Discussion
    Last Post: 28-02-2006, 08:51 PM
  5. Painting Bonnet Scoop
    By Owen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2006, 08:04 PM
