Results 1 to 14 of 14
Thread: Chassis Rails
    VZ Executive
    Dec 2010
    Default Chassis Rails
    Not sure which section to post this is.
    I work for a place that get reids of damaged cars, so Ive got a 2006 VZ SS Damaged for an awesome price however Left Chassis rails is bent, Ive been quoted $1500 to straighten it out how ever I figure an easier and cheaper option would be to buy a standard vz thats also damaged and use the chassis rail from that and put it on the VZ SS
    Is this a plausible idea, Disregarding the time and effort it would take. Would it work?
    Next question is are the vy and vz chassis rails identical?
    Any ideas guys?
    VT
    Apr 2005
    QLD
    They don't have true chassis 'rails' as they are a monocoque design.
    Everything is spot welded.
    Would be less headaches to hand over the 1500 and let them get it to an acceptable condition.
    Is it worth spending 1500 on?
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    Are they going to straighten it out for $1500 or replace the damaged area? what else is damaged on the car, surely it must be pretty bad. I am assuming it has also been written off?
    VZ Executive
    Dec 2010
    Default Interesting
    Car is on the WOVR, not a STAT write of its a repairable write off.
    Its a VZ SS so their still worth round the $17k mark.
    Doesnt seem like swapping "Rails" is such a smart idea after all
    My other thoughts were that I get the shop to simply straighten it.
    All engine, panels and everything else would be removed by myself so Basically the car would go into the shop with the front end being a just a shell for them to straighten up,and a mate of mine whose a boiler maker will be welding it all up for me.
    My other question is, Will a VZ SS 5.7l Basically go straight into a VZ Exec obviously assuming that all other components ie.. radiator, thermos etc.. are also swapped over
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I've seen the front end of cars replaced before.
    Everything from the firewall forward removed and replaced properly and there's no drama. Its expensive but possible.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by vtss5.7litre View Post
    well you will never get it passed (in a million years worth of straightening) in victoria. dunno how tight they are on repairable write off's in perth tho. i had an immaculate repairable rightoff once and they went over it with a fine tooth comb. had to take it back 3 times.
    Nov 2008
    Smithton, Tasmania.
    If its done by a certified repairer its not so hard. In vic they usually sort it all out for you. Costs the world though.
    Faynt11's Avatar
    Faynt11 is offline Feeder of Trolls
    07' VE SV6 Ute
    Jul 2008
    rip the motor out and whack it in a vh... then i'll paint it, maybe do a shadow tone job on it. candy red to cherry red mmmm....
    vy ss manual
    Jun 2011
    vic
    Old Sneakers
    Mar 2011
    Croydon
    What is your suggestion then?
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    VS statesman
    Nov 2010
    melb
    definatly go take it to the panel beaters. they wil use a bench like the car-o-liner or auto robot and shit to like up the rail to the exact spot it should be,
    My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
    WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
    vt s pack manual
    May 2009
    gawler, adelaide
    just take it too a beater, like matt said. a jig system will get it spot on, i wouldnt be messing with chassis rails at all. this is half the reason there is a ban on repairing write offs in other states, because things arent fixed properly. there is a reason crash work cost's a bit, there is a certin way everything is to be carryed out. not saying your dodgey or anything or that you will do a bad job, but the truth is you dont have the equiptment or knowledge to carry out a procedure like this. my 2 cents...
    If you're not driving a manual, you are only steering, not driving
    VS statesman
    Nov 2010
    melb
    Quote Originally Posted by E-T-H-A-N View Post
    this. and if you miss something or dont do one thing right, and you have an accident and hurt someone and your car is investigated you will be ####ed over hard core.
    theres no question here, take it to a beater.
    vy ss manual
    Jun 2011
    vic
    take it to a panel shop rails arnt to hard to repair or replace but it will cost
  1. [SA] WTB: VS OR VU ute rolling chassis
    By piston1 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-05-2010, 06:37 PM
  2. VT Chassis Rusted
    By Secki in forum General Discussion
    Last Post: 18-07-2009, 11:43 PM
  3. 2 chassis numbers on the car?
    By VjamesY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-05-2009, 05:26 PM
  4. Chassis repairs
    By brad92VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 02:02 AM
  5. Is the VIN or chassis number stamped on the actual chassis ?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2005, 08:49 PM
