Results 1 to 11 of 11
Thread: Quick base coat question
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    Default Quick base coat question
    Hi all just a quick question
    When you do a final base coat (metallic Enamel) and you find its a bit patchy from an uneven coat whats the best way to fix it.
    Can you just give it a light wet rub and dust on another coat, Or will clear cover it.
    Im going to do a ute hard cover for a mate just want to make sure if i get an uneven coat if its easy to fix.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    what brand paint is it? what brand gun you using? if you need to rub and rebase a section go no coarser than 800 grit...just have to adjust the air pressure, fan control and amount of paint coming as well as the amount of thinners in the base to get it just right. certain guns and certain brands will mottle (patchy) less than others. not sure you should be clearing over an enamel though... if your trying to get a sick job with a super cheap auto gun dont get your hopes up....
    dont sweat the petty... pet the sweaty...
    May 2010
    Rockhampton QLD
    well im no pro but i have done a bit before the paint is PPG dulon (holden hot house green) i think, As for the gun i will have to have a look it starts with a W. I have had it for a couple of years cost bout $400 when i brought it (1.4 tip) . The shop said to mix the paint at 1:1. I have never had to paint such a big surface area and get it to look spot on just want to make sure im happy with it before i give it back to my mate.
    May 2010
    Rockhampton QLD
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    gonna chuck in my 2c (ready for correction)
    i dont really add that much reducer to start with. i usually throw in 15-20%, but it all depends on how well it flows out of the gun. if the tin has been sitting for a while i will put more in.
    and as hr-ryder has said, its all about setting up everything perfect and having a nice, straight, even hand. put the fan on nice and high, have plenty of paint coming out, but not so much that itll run. make sure you are spraying at room temp or above if its about 16-18 degrees the paint takes ages to go off and it is just painful.
    but yeah, rub it flat, start again.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yes dulon is acrylic laquer not enamel what sort of gun you useing gravity feed or suction feed and at what pressure i spray at no more than 30psi with gravity feed gun
    May 2010
    Rockhampton QLD
    Cheers ari666
    the gun is gravity feed and i normaly run at just over 2 bar iv got it all sanded back will start painting today.
    Aug 2008
    Quote Originally Posted by ari666 View Post
    if its a 1.1 base coat mabe start it with 30 - 35% thinners and go from there. ari says 15 to 20 and mabe thats ok but just stir it around and check before you load you weapon. i use the deltron stuff and if tried to spray it at 20% thinners itd be like hammer tone... cant speak for the dulon stuff... like ari said if its old paint mabe its a little thicker might need more thinners to get it out the gun...
    jd hot stuff's Avatar
    jd hot stuff is offline The power of 253
    VB SL 253
    Jul 2006
    Melbourne VIC
    Just to help you guy's out, more often then not, 90% of base coat (don't matter if its acrylic or 2pac) it should be mixed to 50% paint 50% thinner. With acrylic, make sure you get your base coat to a very nice coverage. Then you can rub it back with 1200 wet. I wouldn't go with 800 as its to course for fresh base. Then rebase. Dont be scared to spay a lil wet, but not over wet. And right after you have done that coat, while its wet. Put down a dust coat if its metallic. You do this by starting at one corner, for example. Top left end of hard cover, spray on an angel, and spray from SW to NE direction. This should hide the mottle (patchy parts) go away.
    n
    Then with the clear in acrylic, it should also be 50% clear 50% thinner. Go over with 3-4 coats, first coat should be no more then 50% so no runs do a cur then make sure next three coats are nice and wet as acrylic drys quick, and not enough clear at once will go dry and dusty. After that, allow to dry then 1200 the hard cover till flat. Then thin down the clear more so you can flow coat it. You can do another 2-3 coats on this. Flow coating will make the clear so much easier to buff shiny.
    You have to remember with acrylic clear, that its not as durable as 2pac clear. The more coats on acrylic clear the better ( no need to do heap's of coats) as when polishing, acrylic wears very quickly. Also
    This is the way id do it, as I am a spray painter and that's how i have been shown, and after using acrylic also, and will help with a good finish.
    When you fall off the pace with the car you brought to the race, I'll be the one who's flying by you kickin' sh#t in your face
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    u can get a sic paint job with a supercheap gun its all in the prep work gun setup and technique
    this is 2k clear over base black mettalic.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    just to clarify,
    2k two pack etc is anything that requires a catalyst or hardener (pack B)
    Acrylic is anything that air dries, inlcuding lacquers and enamel.
    Never sand your final coat before applying the clear, you will knock the head off of your mettalic.
    I was taught to spray mettalics by using solid hand control, keep the gun set to a mid to high pressure, apply light pressure to the trigger, stay about two inches from the surface, maintain high speed and constant distance perfectly, 20 light, dry passes later....
    What kind of compressor are you using?
    Oh and to the question asked. You will need to apply another layer and ensure it is even, the distribution of mettalic paint is critical to the finish. just my 2c
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
  1. Vs V8 base ignition timing question
    By myvscalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 07:30 PM
  2. Quick Question...
    By VR_Project in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 04:34 AM
  3. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
  4. 20lt indigo(blue) met 2 pac base coat
    By juzzyd in forum Parts And Other Items For Sale
    Last Post: 27-06-2005, 06:14 PM
  5. 20 lt indigo (blue) met 2pac base coat 4 sale
    Last Post: 25-06-2005, 03:56 PM
