Results 1 to 9 of 9
Thread: Easiest way to replace radiator support on a vt calais
    Vt Berlina
    Apr 2011
    Deniliquin
    Default Easiest way to replace radiator support on a vt calais
    Hi all, just wondering what's the best/easiest way to replace the top and bottom radiator supports. Got a mate that has a vt Calais that he ran off road and hit a small sucker tree. I'm prepared to drill the spot welds out if it's the simplest way. I can also get hold of a complete front cut of a vt also if that's any easier.
    vy ss manual
    Jun 2011
    vic
    if your not a panel beater dont attempt it if you weld the new front and its not square your bonnet wont close your head lights wont fit and front bar will look shit
    Vt Berlina
    Apr 2011
    Deniliquin
    I am fairly confident in myself to replace the support panel. I'm mainly after th easiest way to go about it and maybe a cost/tolls required for the job. I may end up just doing a complete conversion into my berlina
    VS statesman
    Nov 2010
    melb
    im a beater.
    i use a pick tool to to scribe the old marks so i know where to have the replacement panel when i weld it.
    I use a cut off wheel and grind on the spot weld untill you can see a blue/black ring. (means you have sucessfuly ground through the first layer)
    grind all the spot welds. then the rad sup should just pritty mych fall off.
    then when it is off. i use a belt sander/wire wheel/roloc to clean up where the grinding was done.
    then its crittical to use some copper weld/zink primer where ever there is bare metal.
    then put the new/ second hand rad support on. then move it to the marks where you have scribed. and tec screw it in
    put on bar/headlights/guards check all gaps are even. providing the car wasnt too bad and doesnt need to be pulled.
    then pull all the gear off and weld the sucker on.
    thats the basics there. pm me if u need further assistance.
    My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
    WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    Quote Originally Posted by mattstatesman View Post
    im a beater.
    matt brings up a good point, even if you scribe mark the old location and put it back exactly how it was originally it still might might be out. you might need a rack and portapower to pull it back to square... id suggest getting a beater to sign off on your work before final welding... my .02c
    dont sweat the petty... pet the sweaty...
    vt s pack manual
    May 2009
    gawler, adelaide
    well for a start im pretty sure its illegal for you to fix it... i am a beater too, "mattstatesman" thats exactly how we do it, although i would recomend taking it too a panel beater, and porter pawers arent used much anymore. its all global jig because they are 100% accurate. no beater will sign off on it, its too risky incase something goes wrong... my .02c
    If you're not driving a manual, you are only steering, not driving
    VS statesman
    Nov 2010
    melb
    Quote Originally Posted by E-T-H-A-N View Post
    i usualy work on the auto robots/ car o liners
    VN
    Feb 2011
    Wide bay
    Better off buying a brand new one, unstitching it all, then welding on a whole new one. But as previously said, its illegal for backyarders to do that kinda thing. A panel beaters repairs must be 100% because at the end of the day, they have peoples lives riding on their quality of work. You don't do a satisfactory job at home, you crash and you could be dead.
    VS Berlina
    May 2011
    If you blokes need a bench to square up a VT ,go back to school.Only your heights will be a bitch, but then theres ways to check that aswell.
    But yes using a car-o-liner (or whatever measuring system) is the most accurate way,altough you should be able to do it without one too!!!
  1. Easiest way to replace a VP 3600 Clutch fork without (removing) gearbox or engine?
    By grim596 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2010, 05:44 PM
  2. VP Radiator Support - Removal
    By tr3nt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2009, 01:23 PM
  3. radiator support
    By blockhanson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2009, 09:05 AM
  4. Vr Vs Radiator Support Panel
    By Keesh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 10:48 PM
