Results 1 to 5 of 5
Thread: Installing SS Lip
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default Installing SS Lip
    Hey guys, general question..
    I have the SS lip that came factory off MY car, however after some front end damage it came off..
    I have had the lip temporarily mounted with the two screws that sit right near the wheel arch, and cable tied onto the front bar, to test fit to my new front bar.
    Whats the best mounting option.. glue/screw etc?
    cheers.
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    1992 VQII Statesman
    Sep 2008
    theres screw points in the front lip that match up to the front of the VP bar, the idea is to tighten the screws gradually so the lip sits flush
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    im not so sure the screw points are still with the lip
    vt s pack manual
    May 2009
    gawler, adelaide
    if its a genuine holden bar, on the inside there are little limps about 1 mm circle of plastic, they are the marks for where you drill the holes for the screws to go through you will need to look hard for them. dont glue it on, or it will never come off again. than seem sealer between the gap of the bar and lip, it will give you a more flush look.
    If you're not driving a manual, you are only steering, not driving
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Yeah complete genuine, just it was unremoved... against my will, lets just say that.
    I do recall those tiny holes!
    cheers for the heads up
  1. Installing a HID kit.
    By Luke V8 in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-05-2011, 08:34 AM
  2. Installing Amp
    By ConwaysVSS in forum Car Audio
    Last Post: 23-10-2010, 08:42 PM
  3. help with installing PAC SWI-PS in VZ
    By hod13 in forum Car Audio
    Last Post: 30-05-2010, 04:29 PM
  4. Installing an Amp ... how?
    By nEb. in forum Car Audio
    Last Post: 01-10-2007, 04:05 PM
  5. Installing a Pod, and where can it be done???
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2005, 02:00 PM
