Results 1 to 2 of 2
Thread: How to remove Holden VE front right guard?
    Holden Calais VE
    Jun 2011
    Default How to remove Holden VE front right guard?
    Hi there,
    Can anyone help me at how to remove the ve front right guard? I had remove the guard liner clips, and apparently there are another 2 bolts hidden behind the side skirt. How do i remove the side skirt in order to get access the 2 bolts behind it??
    Any pic with tutorial will help.
    Many thanks~!
    VS statesman
    Nov 2010
    melb
    well, behind the sill cover there is 2 10mm bolts.
    you can part relese the sill skirt to get to them but even then its difficult not to break the clips that are holding them on.
    to take the sill cover off.
    1, remove the aluminium strips on the scuff trims. they are double sided taped on.
    2, take the white/black clips out, this will make it so you can take off the scuff trims.
    3, take out the screws at the ends of the sill cover.
    4, usually i just leaver the sill cover off but this will break the clips.
    but yer you get the idea.
    good luck.
    My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
    WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
  1. [NSW] Front right guard/front bumper/front right headlight VE series 2 - voodoo blue
    By Mrk_Mickey in forum Swap / Wanted to Buy / Trade
    Last Post: 04-07-2011, 12:22 AM
  2. How to remove the front guard flasher?
    By WallyBasher in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-06-2011, 08:13 PM
  3. HOW to remove front right guard from vt
    By ozzy_boy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2011, 03:49 PM
  4. Remove Front guard?
    By Andrew_Guppz in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-03-2010, 05:25 PM
  5. Front left wheel flush with guard, front right within guard. What's goin on?
    By Evman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-02-2007, 12:22 PM
