Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 197
Like Tree62Likes
Thread: Home spray job on my vr commodore
    Vr commodore 1994
    Aug 2011
    Alstonville
    Cool Home spray job on my vr commodore
    Hey guys I'm Wanting some advise on spraying my commodore as It looks shitty at the moment.
    I'm looking at this paint and Puting a primer on as well to fill in alot of scratches on the car I'm open to ideas and anything else I may need? I have the gun, sanding paper, bog.
    Dark Purple Metallic Urethane Basecoat Clear Coat KitFeaturing 5 Star Clear Coat: Automotive Paint, Auto Paint, Car Paint
    Thanks Andrew
    1999 VT
    May 2011
    queensland
    as soon as i saw this thread i thought, oh god, this could turn out bad
    Vr commodore 1994
    Aug 2011
    Alstonville
    Quote Originally Posted by commoVT View Post
    What do you mean?
    1999 VT
    May 2011
    queensland
    Quote Originally Posted by Andrew1994 View Post
    What do you mean?
    all im saying is that it has the potential to turn out really bad
    VS statesman
    Nov 2010
    melb
    if you want a really decent job, and your going to be bogging, make sure someone does it who knows how to rub filler.......
    if your just winging it i can turn pretty bad
    My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
    WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Any Scratches sand right back to bare metal using some 120, then feather it out using some 180. If you still find you have scratches in the metal it's self then use some bog to fill them. Allow for the bog to dry and go hard, then use some 80 to sand it down and some light 120 to feather it out.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    VS Berlina
    Mar 2011
    Woodford QLD
    First, read as much as you can about it. There is plenty of info online and on this forum. Thats what commovt was referring too, there is already plenty of info on the forum to be found, and people will flame you. There is also an ongoing debate on 2k vs acrylic for beginners, I am not getting into that one this time round lol.
    Secondly, do you really want to respray? Unless you want to change the colour, most scratches are usually in the clear top coats, and can be sanded and/or buffed out. This totally depends on the condition of the car of course.
    Thirdly, unless there is an actual dent in your car, throw the bog away. If there is a dent, then try to fix the dent as much as possible with hammers and dollys before using the bog. Bog is badly named, it shouldnt be called body filler, it should be called imperfection smoothing compound Less is best.
    Ok, so if you think the scratches are mostly on the surface, then first try removing them without removing too much paint.. hit em with a buffer and some cutting compound.
    Once you have established which scratches may be deeper, gently hand sand the general area around them with 800 grit wet n dry, used wet. If you can avoid getting through all the clear coat and exposing the base coat, but have effectively removed the scratch, this is the best result. Now all you have to do is hit it with the buffer again.
    If the scratch goes through to the base (coloured coat) but not through it, then you can get a spray pack (make sure you get one with the right kind of paint in it! enamel, 2K and acrylic dont live together well) and put clear back on it.. rub it back with 800 grit until it blends with the rest, then buff it. If there are lots of them, rub the whole car back with 800 grit, then spray it with clear only. Let it dry and buff it up, it will come up like new.
    If the scratch goes through the base coat, then you have to decide whether its worth respraying the whole car. If its a small, un-noticeable scratch, the answer is probably no, unless you are keen and committed or really want a change of colour as well. If there are lots of them or they are really noticable, then you may decide to do a full respray.
    If you are going to respray the entire car, then you are mad not to use primer, simply because its cheap and easy, and will guarantee a much better end result. Bear in mind that if you are changing colours, you also need to do the metal inside the car, like inside the doors, boot, engine bay etc.
    A full, change of colour respray using the paint you have nominated, will require the following stuff additional to whats in the ebay pack you mentioned. Personally I wouldnt go that way, I would head to my nearest auto paint supply specialist and ask them for advice and prices first.
    • 4 litres Hi fill primer
    • 8 litres thinners
    • With 4 litres of primer, you are going to mix about 6 litres of thinners to make 10 litres.. enough for about 6 coats of your car.. with 2 litres left over for equipment cleaning.
    • A whole bunch of wet n dry sandpaper, in 120, 400 and 800 grit.
    • 1200 is also useful for removing orange peel after spraying, but shouldnt be necessary unless you are working on a top coat. Coarser than 120 grit is likely to create extra scratches and extra work, never use it unless you are working on bog, and even then only to remove the high bits. You can sand dry if cutting down bog, otherwise alway sand wet.
    • A bunch of hard work and patience.
    Vr commodore 1994
    Aug 2011
    Alstonville
    Thanks mate I know how to out bog in an Sand it out I've done alot of spraying aswell as I work at a fiberglassing join. And yes I will be using a primer for sure and I'm using a clear coat awell. Could you give me some info on how many layers I need to do for each step? Thanks for all the help it's really helping me out.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Vr commodore 1994
    Aug 2011
    Alstonville
    What's ya bad feeling don't just say you got a bad feeling say why. Talking like a girl.
    VE S2 SV6/A6
    Apr 2011
    Andrew,
    If I were you, and I am being 100% serious, go to a wreckers and ask them for an old panel off a car and prep, bog, prime, sand, paint, clear coat it before you get anywhere near your car.
    Better to make mistakes on a panel that doesn't matter than on a real car.
    It's worth the time for the end result
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    Vr commodore 1994
    Aug 2011
    Alstonville
    I've sprayed my back and from bumper a I needed new ones And I still have the old bumper witch I have done some Practice on and came out good dosnt bother me to much if it dosnt come out in shop quality I just want it to be a better colour then it is I'm soon it more for fun and to #### around.
    commodore
    Aug 2009
    australia
    get yourself a long body file/sanding board so when rubbing back the bog you will hopefully wont have dips or ripples in the end result and remember a good paintjob is mostly in the preparation the better and more time you spend on preparing your car for paint the better the end result is likely to be.if your using metallic the whole car will have to be rubbed back with 600 grit paper before topcoat.
  15. #15
    Vr commodore 1994
    Aug 2011
    Alstonville
    Yeah I have a long sanding file. So you mean rub the paint on out on befor putting the clear coat on?
  16. #16
    Vr commodore 1994
    Aug 2011
    Alstonville
    So give it a good sand with 600 grid and a good buff then run over it with was and grease remover befor puting the clear coat over the new paint? is that right that's what I've been told?
  17. #17
    1999 VT
    May 2011
    queensland
  18. #18
    Vr commodore 1994
    Aug 2011
    Alstonville
    When people say cut arylicc back wIth 1200 grid paper dose this mean after you have done the clear coast or befor you put the clear coat on?
  19. #19
    1999 VT
    May 2011
    queensland
  20. #20
    Vr commodore 1994
    Aug 2011
    Alstonville
    Rightio smart Ass I'll put a picture up in a few weeks to show you cause your such a negative person.
  21. #21
    1999 VT
    May 2011
    queensland
    ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhh god, theres gonna be pictures
  22. #22
    VS UTE, HT MONARO REBUILD
    Dec 2010
    commoVT i dont think you have to be negative about him wanting to do his own work, if he want to do something to his car by himself so he can learn then thats fine, if he stuffs it up it's only paint and can be sanded back and resprayed, i think its good that he wants to do it himself, and asking questions on how to do it is the only way you can learn.
  23. #23
    1999 VT
    May 2011
    queensland
    Quote Originally Posted by Shooter 88 View Post
    time shall tell
  24. #24
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, OP if you are dead serious about going ahead, that paint kit you linked looks like cheap rubbish to me. i personally wouldnt touch it, but .. yeah, just but...
    this thread goes into a fair ol' whack of detail: Backyard Spray Job on VN commodore (Black) need info
    bit more in here: first time spray painting advice on what tools and paint i need
    and more on the actual tools you will need: specific tools, their use and what they look like
    have a read of them, then post any questions. if you post questions that have been covered in one of those threads, prepare for a smart arse answer (he he he)
  25. #25
    1999 VT
    May 2011
    queensland
    ooohhhh nooooo. please dont give him any ideas!!
  1. Backyard Spray Job on VN commodore (Black) need info
    By Bz Kn33z in forum Spray Painting and Panel Beating
    Last Post: 16-09-2011, 01:51 PM
  2. [NSW] HVAC unit from VR Commodore FREE TO GOOD HOME
    By keza87 in forum Parts And Other Items For Sale
    Last Post: 24-08-2009, 08:37 PM
  3. Vn aero kit wants a new home (a v8 home)
    By hi_ryder in forum Parts And Other Items For Sale
    Last Post: 09-05-2009, 09:55 AM
  4. Replies: 4
    Last Post: 23-09-2006, 03:21 PM
  5. home sweat home
    By VN-88 in forum The Pub
    Last Post: 23-04-2006, 02:34 PM
