Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By one_and_only2004
Thread: Spray painters advice ?
    VQ Caprice
    Apr 2009
    Castlemaine
    Default Spray painters advice ?
    hey,ive go myself into abit of a situation and need abit of help,Ive preped my car for painting its sitting in grey primer its all been guide coated and is nice and stright ready to go. im painting in astroid silver and ive sprayed a few scrap panels and its hard too see the silver go on over the grey primer.so just woundering what my options are ? was thinking maybe putting a few more coats of primer on with a black tint ? or just spraying the whole car flat black? would either of these options effect the finish result ? im using du pont lucite 400 ...cheers
    1999 VT
    May 2011
    queensland
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    how many coats have u done
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VQ Caprice
    Apr 2009
    Castlemaine
    VQ Caprice
    Apr 2009
    Castlemaine
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    I'm only subscribing to this thread for commoVT's replies.
    Good luck with your project ST8OOH.
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    Quote Originally Posted by ST8OOH View Post
    thats not very helpful.
    Have a quick glance through this thread and you'll see that, as a rule, he is not very helpful.
    VQ Caprice
    Apr 2009
    Castlemaine
    Quote Originally Posted by Mk2 View Post
    ok thanks for that
    VS SS 5L
    Oct 2008
    Its not uncommon for people to put a white or black underneath other colours. If its that hard to see i'd just put some cheap white on it then go with ur silver
    VQ Caprice
    Apr 2009
    Castlemaine
    Quote Originally Posted by Brendon Porter View Post
    how many coats of the white would you go ?..thanks
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    VS SS 5L
    Oct 2008
    Enough to make it not grey any more, so you can see your silver going on it better i guess. You should also bear in mind, once you spray a coat of silver, its gonna be harder to see where you've been again, and for the next coat and the next coat will be harder still. Maybe just stick to a uniform pattern and go from there. Just make sure that whatever u spray your nice silver onto is all flat n shit, no runs n stuff.
    1999 VT
    May 2011
    queensland
    ohhhhhhhhhhhh no, its happening all over again
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by commoVT View Post
    Do you have anything useful to say?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  15. #15
    1999 VT
    May 2011
    queensland
    Quote Originally Posted by one_and_only2004 View Post
    clearly not...
  16. #16
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ok, just to save you a lot of time, effort and money. go to bunnings and get 3 or 4 halogen spotlights. you need at least one fluro tube and a couple of halogens. set them up at all different angles and as you are spraying, get your head down so you can see the spotlight in the sheen coming off the gun, the three different types of light (sunlight, fluro tube and halogen) shine a different type of light and will help show how the metallic is sitting, so you can go back over spots that are not right. its a lot harder than starting with an oche or black base, but youve done it now, and IMO this would be the easiest way.
  1. Any Panel Beaters/Spray Painters?
    By Chrispy in forum Spray Painting and Panel Beating
    Last Post: 12-07-2011, 02:31 AM
  2. spray painters in dubbo NSW
    By VS commy in forum General
    Last Post: 11-05-2011, 07:01 AM
  3. Spray painters in Adelaide NorthEast Area
    By Clinster in forum General
    Last Post: 08-03-2007, 02:42 PM
  4. any pro spray painters here???
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 10:18 AM
  5. Spray Painters
    By Robbie in forum General
    Last Post: 20-02-2004, 03:16 PM
