Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By The pig
  • 2 Post By showbags
Thread: has anyone actually sprayed clear on bare steel?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Default has anyone actually sprayed clear on bare steel?
    hi all.
    has anyone ever sprayed clear straight onto steel? does it stick? in theory it would just peel off but stranger things may have happened.
    am thinking of polishing my block, and just coating it with a liberal amount of 2k clear. even if someone has sprayed clear on their brake calipers, did it stick?
    thanks
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    i remember years ago i made a coffee table out of mild steel pipe and some flat bar with a glass top, i used the sanding disc on the grinder to give it a clean up mostly just to get the rust off and cleared it over, it still looks pretty good. but it just sits inside, being on car bits it might flake off or something.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    CV8 Monaro & VE SV6
    Sep 2009
    Have you thought about clear over gun metal grey or a pewter? If you played around with the shades, it might get close to a bare metal look. Obviously not shinny as bare metal, but saves having to pull the motor and do it again when the "clear only" peels.
    69 rs ss camaro/ rodeo dual cab
    Jul 2011
    adelaide
    Default clear coat
    Hey mate i sprayed and powder coated harley davidson and buell wheels for six years and i used to clear coat a lot of them we used to machine the castings run em through the wash tanks then through the ovens to dry and heat them then shoot a sh*t load of clear coat straight onto the alloy and never had problems so it works with aluminium (hot) guess it should work with steel too. The clear we used to spray was very thick almost like oil
    ari666's Avatar
    1966 impala
    Mar 2009
    sweet as. i might actually give it a 'test run' on the b lock in the car atm. just grind a bit of block then hit it with clear and see how it lasts. i know 2k can take quite a bit of temperature, and people spray their blocks all the time and it lasts ok, so i am hoping for good result
    watch this space
    TOW PIG
    Nov 2009
    New Plymouth NZ
    In my opinion i wouldn't bother.
    The tiniest bit of moisture in the air and it will start the oxidization process in seconds, you would have to have 0% humidity and that aint likely to happen in Melbourne is it lol.
    Then you have the issue of the clear turning yellow due to heat, and it'll get worse as time goes by.
    The heat will be trapped in the block by the paint, the hotter the block gets the yellower the clear will get.
    Have done a few projects where i've cleared or candied / cleared bare metal and the look a million bucks....................for awhile, maybe a a couple of months or even a year but end results is ALWAYS the same...................rust.
    I try to talk customers out of the idea but if they insist then i don't guaranty (sp?) the job and explain to them why i won't.
    Just my 2c mate. 27 years in the refinish / airbrush industry gives me a little insight lol.
    ari666's Avatar
    1966 impala
    Mar 2009
    you bastard. sif give me words of wisdom
    damn. back to the drawing board. maybe i will look at heavy fleck silver or something (as suggested).
    i mean, i dont hate chevy orange. in fact it looks really good with the green engine bay. just thinking of something unusual.
    TOW PIG
    Nov 2009
    New Plymouth NZ
    Haha.
    What i'd do.
    Silver dollar metallic (Extra high sparkle) basecoat tinter - 1/64 silver metalflake - candy colour of your choice = job done.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    ari666's Avatar
    1966 impala
    Mar 2009
    VS UTE, HT MONARO REBUILD
    Dec 2010
    ari, just an idea got no idea if it would work but on our monaro we have a clear primer over the metal, why not try get some clear primer for the engine?
    ari666's Avatar
    1966 impala
    Mar 2009
    Dec 2010
    well it's what the guy has sprayed on our car after he soda blasted the body, it seems to be good stuff as the body hasn't started rusting and we live pretty much next to a bay
    EDIT: just remembered it was a clear etch primer.
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Hey Ari, POR 15 make a clear coat designed for polished alloy & chrome wheels. it sticks to them I think it will stick to bare metal and it has a rust inhibitor in it as well. I've used their paints on calipers and rotors before without any problems at all.
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
  16. #16
    TOW PIG
    Nov 2009
    New Plymouth NZ
    Quote Originally Posted by ari666 View Post
    and we have a winner!!
    Clearcoats - Por-15 retailers, clear coat protectant, rust preventive paint, fuel tank sealer
    thanks for the info mate that stuff looks perfect
    That looks like the go mate.
    BUT (yes there's always a 'but')................DO NOT get it on anything you DON'T want painted lol.
    A mate used black POR 15 in his EH engine bay, after a few months you could not budge it, even a good hit with a hammer did nothing lol.
    Oh, and DO NOT get it on your skin............it aint coming off in a hurry lol.
  17. #17
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    Sorry, forgot to add it actually sets harder than powder coating, and if it dries on your skin only time will remove it. Or 40 grit sand paper and take a few layers of skin with it.
  1. Mild Steel or Stainless Steel Exhausts?
    By DrZ in forum Just Commodores Polls
    Last Post: 29-04-2011, 09:15 AM
  2. Commodore VE Steel 16x7 Steel Rims
    By Leo.Bullterrier in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-03-2011, 12:31 AM
  3. Opinion Altezza clear tail lights + crystal clear indicators for a VR Wagon.
    By Raremetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2010, 06:15 PM
  4. FS: clear side indicators, vs clear taillights, vs 2 1/2" exhaust, speaker pods
    By lowrida56 in forum Parts And Other Items For Sale
    Last Post: 02-02-2008, 02:57 PM
  5. clear side indicators and clear boot garnish for vp?
    By gocommygo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 07:05 PM
