Results 1 to 15 of 15
Like Tree7Likes
  • 2 Post By CAPRILICIOUS WL
  • 1 Post By ari666
  • 1 Post By Reaper
  • 2 Post By Jesterarts
  • 1 Post By aaronevolution
Thread: Rotor Paint
    Corolla
    Sep 2011
    Australia
    Default Rotor Paint
    What do you guys think of this rotor paint job?
    I'm a bit concerned that the paint isn't meant to go there.
    TOW PIG
    Nov 2009
    New Plymouth NZ
    WL CAPRICE
    Mar 2011
    Looks neat
    It should be fine as it will wear out the contact surface after a few applications of the brakes.
    Just apply the brakes very slowly at low speeds because the paint melts and the pads stick on the roter.
    This is mine,
    then after a few drives it was back to normal.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    omfg.. is this thread really happening?
    why didnt you just wipe the paint off while it was wet? you realise that its gonna destroy your pads now.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    failthread
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    On your VN that's worth +20kw for red brakes.
    Seriously though...WHY DID YOU PAINT THE CONTACT PART OF THE ROTOR!!!!!!!!!!!!!!
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by caliper_paint View Post
    Dangerous...
    Quote Originally Posted by CAPRILICIOUS WL View Post
    Looks neat
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    sweet baby jesus
    Im................ speachless...........i.just. I just dont know why you........
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    aaronevolution's Avatar
    aaronevolution is online now Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    I think you missed a spot.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Looks neat
    This is mine,
    That looks mint. Too bad your pads will be rooted. But its all good if you cbf changing pads a week after painting rotors
    WL CAPRICE
    Mar 2011
    Lmao some reactions are funny there ^^ lol.
    But honestly guys I drive the car every day of the week short and long distances and the pads are still just as good and it's been about 5months now.
    I have also had a look at the pads themselves and they are fine.
    There was only a thin layer of spray that came on the contact surface which literally was gone after the brakes were applied about 10 times.
    Now for those who ask why the contact surface, this is to end up with a clean result. What I mean is the pad doesn't cover the entire surface of the contact part of the roter.
    The rust will still be partially present on the surface that the pad doesn't contact.
    Like so:
    This is after a 5km drive: back to normal.
    Caliper_paint Op, don't stress. Lol
    Just remember to apply the brakes very slowly to wear the paint off before u go for a drive on main rds.
    Shuld look sweet.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Like so:
    Shuld look sweet.
    The responses are well justified. You are doing something that severely compromises tyour braking system in the short term and then will keep having a negative effect on braking performance until you change pads or wear them down enough that the contaninated layer has been worn off.
    Brakes work because of the friction of the rotor and the pad. You are introducing something that will pretty much permenetly contaminate both surfaces.
    The paint will get into the porus surface of the rotor braking area and also into the surface of the pads. And it's not going to have a possible effect on either.
    You also have to ask yourself how much of the paint particles have managed to move into the piston area's and moving components of teh caliper making them sticky and compromising operation.
    Apart from the fact that going for a drive to remove the paint from the rotors is just asking for trouble, I would be changing pads asap.
    Scratch that, I wouldn't be painting the barking surface of the rotors to start with.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by Jesterarts View Post
    ^ That.....
    1997 VS II - S
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
  15. #15
    Corolla
    Sep 2011
    Australia
    I should have included more details in my original post. This is not my Commodore - I did not paint the rotors. I was out walking when I saw this and it didn't seem right to me - I grabbed a quick picture so I could check with someone who would know for sure (that's you guys). The driver of the car wasn't there at the time, but I've seen him driving around the neighborhood, he's just a young guy - probably his first car. Even if he was there, I'm not one to question another man's ability to maintain his own car without being damn certain that it's worth questioning him.
    So like I said, I was concerned the paint wasn't meant to be on the contact surface of the rotor. I was considering mentioning it to the owner if the responses overwhelmingly suggested it was dangerous, but given only one reply said it was while others said it would reduce performance then I think I'll just mind my own business.
  1. VK rotor arm issues
    By DJL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2011, 12:01 PM
  2. Top of rotor thickness
    By NeddyBear in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2011, 03:37 PM
  3. ve ssv rotor size
    By Gambel in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-11-2010, 06:50 PM
  4. rotor upgrade
    By richardpalinkas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2010, 07:09 PM
  5. rotor covers
    By ad45 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2010, 10:03 PM
