Results 1 to 2 of 2
Thread: Additional Layers of Base (Once initials are dry)
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Default Additional Layers of Base (Once initials are dry)
    Hey,
    Got a small issue where i've layed down 2 or so base layers of a metallic paint however it needs a few more before i hit it with the clear.
    I wont be able to get to the paint shop for a bit so the base is going to cure over the next couple of days.
    How should i prep what i've painted so far so i can put down the last layers of base?
    Everyone seems to have mixed views on whether or not you should sand a metallic prior to the clear top anyway (some think its ok others say itll scratch it to the shit house).
    Basically my plan was to wet-sand the top coat with a super fine grit (1200+) then do the last few layers however does it need it? Can i just spray over the top of the base as is or does it need to be sanded back?
    Thanks,
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    wagon
    Nov 2006
    South East Vic
    If it's basecoat and not acrylic you have a 24 hour window (not that I would leave it that long) before you have to sand it. in saying that if you plan to leave it for any amount of time longer than 1 hour I would just get a grey scotchie and go over your surfaces. just do it lightly and don't do it wet!
  1. Additional AUX inputs
    By calais24/7 in forum Electrical Wiring / Questions
    Last Post: 19-05-2011, 06:43 PM
  2. Removing different coloured paint layers
    By dzach23 in forum Spray Painting and Panel Beating
    Last Post: 05-01-2011, 05:28 PM
  3. Wiring additional Screens - WK Caprice
    By Capriced in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2009, 04:15 PM
  4. Adding additional alarm sensor
    By BANKS in forum General
    Last Post: 08-07-2008, 10:04 PM
