Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By vpcalais6
Thread: welding tiedowns
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Default welding tiedowns
    so after a very good search on the forum and on the google machine, i have turned up with a few answers but not exactly what i needed. i am wanting to weld a few of the tie down hooks back onto my rails (to put a cover and to tie stuff down when hauling) but in a different way from the original so that you really cant see them. but what i want to know is can i weld them on without ruining the paint on the outer side of the rail. i dont care about the inside, and im not fussed if the paint changes in colour a bit, but if it completely ruins it then ill look at something else. also planning on using a gassless mig off a mate.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Dec 2010
    the rails along the top of the backsides on the ute
    They are detachable so i can get in there with a welder
    Dec 2010
    Mase1990's Avatar
    Mase1990 is offline VY Storm 03
    VY Storm 03
    Apr 2010
    NSW, Cessnock
    ari666's Avatar
    1966 impala
    Mar 2009
    well if you are asking if itll burn the paint, yes yes it will. if you weld in the inside, then the outside will get burned. the idea of welding is to mix two metals together. so the whole area needs to be cherry red hot and at the melting point. i think (but dont know for a fact) that paint's melting point is significantly lower than steels melting point.
    (lol, that was a joke btw)
    Mase1990's Avatar
    VY Storm 03
    Apr 2010
    NSW, Cessnock
    If the paint is directly on the other side of what youre welding, the paint will melt and bubble and go brown. Look shit. And gassless mig is also shit.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Why not get a hardcover, and put something like these in the tray?
    Itll look a lot better, and be as functional..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by VKCOMMO View Post
    Why not get a hardcover and put something like these in the tray?
    realised what you ment.
    but how would they hold down the tonneau?
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    vn
    Nov 2009
    noble park
    round up a bit of scrap ie old guard or door and run a few welds on it and see how the welder burns paint off.
    Dec 2010
    Thanks for the responses so far. now for info.
    The paint is not directly on the other side, im welding onto an existing peice that it about 5mm thick.
    Hard covers are very expensive for new ones and kinda unnecessary for me as i will be getting a sports bar which means i need a special hard cover = more money, plus with tools and other big objects the lid has to be up.
    The welds are not going to be long continuous welds but more of an extended tack weld.
    Hopefully this gives you guys some better info to go off.
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    could you maybe drill holes. and nut/washer the bits down?
    ive also seen some "roll up" tonneaus that are solid but kinda wierd, might work? (imagine ford ranger style)
    Dec 2010
    bolting them on won't work unfortunatly, already had a think of that. i have seen those roll up tonneaus but arent really keen on the idea.
    but today a mate of mine showed me his navara ute, and it had a really good cover on it that had brackets that bolt on the inside of the tray and the cover has clips on it to hold on to the brackets, think ill do a bit of research on that style as it means no welding.
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Shooter 88 View Post
    You mean almost exactly the same style VKCOMMO pointed out?
  15. #15
    Dec 2010
    VKC suggested a hard lid/ tubliner which is not what im after, this type of design is much like the style of cover the VU utes use. it has a long bracket that runs the length of the side and then the cover stretches over it and clips on.
  16. #16
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    Could you just drill then nutsert the holes the you will be able to screw you tie down points on
    CHEV badges Australia says no
    fighting online is like racing on a special olympic. Even if you were to Win! your still ####ing retarded
  17. #17
    vpcalais6's Avatar
    V6 manual vp Calais
    Sep 2007
    central coast
  18. #18
    Dec 2010
    that is a possibility, i think ill just give this welding ago and if it doesn't work out on the first one ill try some thing else.
  19. #19
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    have you looked into maybe getting a vu style soft cover?
    with the clip in rail things down the sides.
    have these where the old hooks would have been. so it blends in.
    if a soft cover from another model doesnt fit im sure an auto trimmer (uphosterer) could modify it.
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
    mate i reckon the nutsert would be a winner. youll be sorry if you try and weld something. especially something as thin as panel steel and clips.
    with a gasless mig
    and your first time welding?
  21. #21
    Dec 2010
    i have done a few other welds but they were with an inverter stick welder which is completely different.
    im gonna do some more research and ill get back to you. but i do really like the VU style cover but no one makes it for VS, but as drawnnite said i could get it modified by an auto trimmer.
  1. Some welding help please
    By vxcustom in forum V6 Development And Modification
    Last Post: 25-10-2009, 10:06 AM
  2. welding?
    By Peter89 in forum General
    Last Post: 12-04-2009, 01:04 PM
  3. TIG Welding
    By Wrayza in forum General
    Last Post: 22-12-2006, 08:01 PM
  4. welding
    By vicarious in forum The Pub
    Last Post: 02-11-2006, 06:34 PM
  5. welding??
    By V3N0M in forum General Discussion
    Last Post: 17-06-2006, 01:29 PM
