hey guys,
as you can see in the picture i have a major problem. long story short i left a magnetic p-plate on there too long and it baked itself to my bonnet. very stupid i know. the high spots are from me gluing other p plates to the patch, A) to hide the big ugly patch and B) because it wont stick to it.
so far i have tried
-razor blades
-metho
-fishing line
-hair dryer and each of the above
the only way i can see it going is to sand it back and get the bonnet repainted.
any suggestions?
have you tried metholated spirits and then put gladwrap over it to stop it from evaporating before it softens the rubber
Prob a crazy idea but what about a bigger magnet upside down under the bonnet to push it off?(prob wont work..)
WD40... that shit is mans best friend...
Spray it on... let is soak in for a while and then use some floss to peal it off.
Good luck!
If the rest fail try a Pin Stripe Removal Caramel Wheel.Up until 5 minuates ago I though they where called camel wheels.
Complete Paints Limited! :: Pin Stripe Removal Caramel Wheel
also try a citrus spray they work really well with stuck on residues but that might be a little baked on worth a shot though
mate, there are a couple of rust spots from where you have tried to get it off b4. sad to say, but thats a rub and respray job.
