Results 1 to 5 of 5
Thread: Primer sealer question
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default Primer sealer question
    Gday, I got two cars that need a re spray. One appears to be enamel...
    (paint comes straight off with acrylic thinners).
    And the other a urethane..I think?...
    (I put acrylic thinners on and rubbed on the paint, but nothing cam off) so I asumed it's a urathane.
    Anyway, is there a primer sealer that I can use as a barrier on both cars so I can spray acrylic on top?
    Cheers.
    VE SV6 Ute Series 2
    Dec 2011
    hey mate usually enamel is solvent resistant so I would say the first car is acrylic. The second car could be 2Pack. Are they factory colours. What cars and year model are they.
    Either way you can paint acrylic over acrylic and over 2 pack.
    You can't paint 2 pack over acrylic or enamel over anything.
    There is a product called barcoat isolator that can go over enamel or 2 pack which will give a barrier for the new paint.
    I don't think you well need it but just acrylic primer then paint. I have a few videos and guides on my website if ya need it.
    Hope this helps.
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by CustomSprayMods View Post
    Hope this helps.
    Thanks heaps for that info.
    The black paint is a 1982 Mazda colour..ZP..(which instantly turned runny
    When hit with thinners)... however someone painted the roof and bonnet with a paint that only lightly
    comes off with the thinners if u rub hard.
    The other is 1967 Toyota colour... but someone painted over the old 60's paint with Woteva it is now that won't come off at all with acrylic thinners, even when rubbing hard? I don't know wot type paint they
    sprayed in the 60's either?
    The only reason I thought enamel turned runny with thinners, was just something i read while searching a paint site. I personally have no idea. Do you kno of any other methods of checking this?
    Cheers again
    VE SV6 Ute Series 2
    Dec 2011
    back then was either acrylic or enamel. Using thinners is the only way to tell without a pro looking at it. To be safe you should just paint strip then etch prime then paint.
    CSM
    Apr 2008
    Kwinana, Perth
    CSM
    Yeh the paint stripping is wot i wanted to avoid, as my backs Fu**ed and I can't manage it.
    Mite hav a go at that sealant u mentioned tho. Sounds good.
  1. Car Primer
    By EDGE3 in forum Spray Painting and Panel Beating
    Last Post: 11-09-2011, 06:24 PM
  2. Primer
    By NFNSUS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-08-2010, 04:21 PM
  3. Should i use primer?
    By FATMAT in forum General
    Last Post: 01-07-2008, 02:32 PM
  4. 515 gasket sealer
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2008, 10:04 PM
  5. o2 sensor V.S silicone sealer
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2005, 09:55 PM
