Results 1 to 7 of 7
Like Tree4Likes
  • 2 Post By ari666
  • 2 Post By HamaTime™
Thread: Complete Spray with or without Sunroof
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    Default Complete Spray with or without Sunroof
    so pretty simple question.
    is it easier to do a complete respray with or without a sunroof in?
    i only ask this because firstly im curious, and 2ndly this may occur one day.... (dont hold your breath in otherwords)
    also similar question and i cannot be bothered making 2 threads.
    easier to retrim fabric on ceiling in cabin with or without sunroof?
    i would assume before, but there could be a possibility.
    Thanks
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    are you going to cut a hole for a sunroof? in my expierence that is a BAD idea. you can never get the drainage right on aftermarket sunroofs and they rust in about 3 months. factory sunroofs (at least proper ones) have water escape tubes running either down the A pillar or the C pillar which stops the water pooling in the sunroof channel. if water gets stuck there, then dirt follows, then rust comes shortly after. not to mention you will be cutting areas where you may not be able to seal the exposed metal (paint/epoxy, whatever) which will rust immediatly.
    sunroofs are a BAD idea all round.
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Drawntite, I swear 367 of your 368 posts have been related to sunroofs.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by HamaTime™ View Post
    i know =P
    but oh well... its better then asking about what size exhaust for a vs commo every 2nd day =P
    and thanks for that ari.
    good info to use for the future.
    i guess that puts an end to the idea. =P
    although it would be nice and different
    but out of more curiosity.
    what if the car was pulled down hole cut and then resprayed and sealed. then sunroof goes in (possibly with drainage tubes aswell)?
    or would it be the same, because its not done in the factory?
    also what if it is the same model as they use in the factory? (webasto)
    just read that ve sunroofs are bolt in kits? so does this mean there are no drainage tubes either?
    also what do you mean byt he sunroof channel ari?
    and im guessing youve seen this on cars from work?
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    so back to the original question
    would it be easier for a panelneater to do a full respray before or after a sunroof goes in?
    i only ask because if i ever seriously consider putting an 8 into the ute id love to completely rebuild the ute and a respray woud be in order and ive been 'considering' a sunroof lately as hama would say its been in every post =P
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Sunroof ftw. The factory sunroofs aren't all that great either.I've seen a few where the drainage hose has split or come off and run onto computers and caused massive issues. With an aftermarket sunroof you can make sure it's done properly and hoses are sealed and everything is watertight.
    ari666's Avatar
    1966 impala
    Mar 2009
    my vote is for after. takes longer to mask it but loads less prep work for final spray. blocking back a roof takes a while cos' its the first and biggest panel you see when looking at a car, so it has to be done well.
  1. Sunroof
    By Pookie in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-11-2010, 08:13 PM
  2. Sunroof
    By MickT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-10-2010, 01:18 PM
  3. Ssv sunroof
    By Haluigi in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-09-2010, 07:24 PM
  4. Sunroof
    By 06vzcalais in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-01-2010, 09:47 PM
  5. Replies: 4
    Last Post: 23-09-2006, 03:21 PM
