I just removed the mud guards off my VX II S-pac and found this pushed in area on my side skirt:
Side View:
Underneath view:
I am guessing that the mud guard has pushed into the side skirt to create the damaged area.
What are suggestions for fixing this? I have not had much experience with this type of stuff.
My thoughts would be to
1. Pull it out by twisting a screw into the pushed in area
2. Fill the holes/uneven areas with bog
3. Cover with light amount touch up paint.
Thoughts or help with this area would be much appreciated!
id say that damage is from a jack.
maybe try and find another skirt the same colour or just pull it out yourself the best you can
heat it up really hot with a heat gun, then poke it out with a screw driver. then let it cool.
then sand it down. then obviously prime and paint.
My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
