Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By ari666
  • 1 Post By Bellicose
  • 1 Post By ari666
Thread: painting over chrome
    Parabola's Avatar
    Parabola is offline California Dreaming
    XR6T
    Sep 2010
    Hervey Bay QLD
    Default painting over chrome
    gday guys, on my 18" wheels it has chrome inserts.
    the chrome inserts can be detached from the wheel itself, im going to be taking them off and repairing my wheels as all of them have gutter rash, the other part of the wheel is black and i will just respray them.
    but i want the whole wheel to be black so im wondering whats the best way to go about spraying these chrome inserts black? because i was told its hard to get paint to stick to chrome.
    heres an attached picture of my rims so my thread makes a little bit more sense.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    Faynt11's Avatar
    Faynt11 is offline Feeder of Trolls
    07' VE SV6 Ute
    Jul 2008
    use a 2k etch primer first. self etching primers don't always adhere to chrome.
    also, is it definitely chrome? i've seen wheels with "chrome" inserts that are just painted plastic.
    If its plastic sand back and prime.
    Parabola's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    Quote Originally Posted by Faynt11 View Post
    yeah im very unsure on them being actual "chrome" they are very light for chrome if so. but i will still go with the different brand of primer.
    dumped vk 202 efi calais mok-up.
    Jan 2012
    berri s,a
    yeh they would be plastic... use wet rub 2000 n ensure surface is smooth before painting... but also when ya prime it giv it a coat at a time for best results.... rub bak wiv 2000 ensure smooth n no pits before spraying colour on it...
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    just wipe over it with prepsol and hit it was an aerosol can. wouldnt waste my time prepping it. you will spend 2 hours sanding and prepping and itll look the same as if i had done it in 2 mins.
    Parabola's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    yeah was thinking of doing that, also with the rim as well, should i sand my gutter rash back and smooth it out then hit it with prepsol as well?
    ari666's Avatar
    1966 impala
    Mar 2009
    probably better to get to that with a flat file. depending on how bad it is, you may need a re-balance after.
    Parabola's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    yeah on one wheel its pretty deep, dont know if i can get it smooth enough.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Post up a shot of the deep gutter rash
    TOW PIG
    Nov 2009
    New Plymouth NZ
    Quote Originally Posted by dwayno80 View Post
    Really? 2000? The guy would still be doing it at xmas.
    OP, do what ari666 suggests.
    Parabola's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    U could sand that back, but it'll throw out the balance by a shitload. A rim repairer, may fix it filling in the gaps, but may also lathe it back. If they do that?!?
    ari666's Avatar
    1966 impala
    Mar 2009
    nah ive seen much worse get repaired and it balances up ok. taking the tyre off is pretty much a sure-thing though. tyre off>flat file evenly all the way round> send it off for some 2k (along with the caps)
  15. #15
    GothicKidd's Avatar
    GothicKidd is online now ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Can I ask how it will through the balance off? Not that I'm planning to do anything like that but yeah.
    Would moving a Lock nut after 5000K's + cause it to throw it out of balance?
    Sorry for Hi-jacking.. but was just curious. sorry.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
  16. #16
    ari666's Avatar
    1966 impala
    Mar 2009
    no. wheel nuts are too close to the center of the rolling axis to make a difference. the balance would be thrown off by one side of the outer rim being a slightly different weight to the opposite side. 5grams would do it. which is why you need to flat file it evenly all the way round.
  1. Painting chrome centers...
    By Daggy082 in forum Spray Painting and Panel Beating
    Last Post: 13-06-2011, 06:21 PM
  2. Painting chrome
    Last Post: 17-03-2011, 08:29 PM
  3. Replies: 5
    Last Post: 07-08-2010, 09:08 AM
  4. painting over chrome
    By mightyredvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2009, 09:20 AM
