Results 1 to 9 of 9
Thread: Injectors
    Faynt11's Avatar
    Faynt11 is offline Feeder of Trolls
    07' VE SV6 Ute
    Jul 2008
    Default Injectors
    Hey Andy,
    I'm considering swapping to E85 in my VE sv6 Alloytec and was wondering what size Injectors I should be using? Also I have intentions of
    supercharging it when my bank account is ready for a beating. If i were to buy injectors to suit a supercharged E85 setup would that be
    too big to use without the charger?
    Cheers,
    Dean
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    E85 requirers a fari sized fuel system. you would need to upgrade lines and pumps and possibly go a surge if you aim to crank some power out of it . i would suggest 800cc and bigger for the injectors
    Current Ride:2003 Vy SS series2. Single mount GT45 and intercooled, E85, 1000cc injectors, ARP Head Studs, ARP Rod Bolts, 2 spd powerglide . 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3600rpm stall converter, 3:46 Diff Gears. MADE 600RWHP ON 14PSI
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    Andy@SquashPerformance's Avatar
    Andy@SquashPerformance is offline Squash Performance
    2009 G8 GT
    Mar 2010
    Wisconsin, USA
    Quote Originally Posted by Faynt11 View Post
    Hey Andy,
    Cheers,
    Dean
    I think if you size the injectors right and get some high quality ones (Injector Dynamics comes to mind) they should work fine before you really need to max them out. Idle and easy cruising are going to look/act very similar with or without the supercharger...
    Andy
    2009 G8 GT
    Mar 2010
    Wisconsin, USA
    Quote Originally Posted by Raptor Charged VX View Post
    Surge tanks are not necessary, and don't belong on the street IMHO. Our fuel systems will move enough fuel to keep the 800cc injectors happy.
    Andy
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by Andy@SquashPerformance View Post
    Andy
    That's all well to say when you've just spent $120 at BP, but what about when you're running below 1/2 a full tank? a few WOT runs are going to suck the swirl pot dry which is something you don't want.
    VZ Thunder - 424RWKW Turbocharged V8 - Parts by AKO Performance
    2009 G8 GT
    Mar 2010
    Wisconsin, USA
    Quote Originally Posted by one_and_only2004 View Post
    Sorry man you are incorrect about that. My setup keeps the bucket full at all times. Even with as little as 1" of fuel on the bottom of the tank, it pulls that fuel up and fills the swirl pot to the top and overflows down the sides. Even under WOT there is the same flow of fuel from the tank into the swirl pot. That's one of the reasons we keep the stock bucket - it literally fills from the bottom. My system will suck the tank just as dry as the original setup. If you want video evidence I will be happy to make one this week if I get some time.
    Andy
    Mar 2008
    Kind of wish I knew about your setup before I went and did my fuel system then, would have saved me putting a surge tank and all that crap in the tray - do you do anything for VZ's or just VE?
    2009 G8 GT
    Mar 2010
    Wisconsin, USA
    We're working on the GTO/VZ pumper right now, but it's not yet available...
    Andy
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Andy
    Very impressed with the response. Sounds like awesome fuel system
    Raptor Superchargers - Boosting S1/S2 3800's VN - VR, Ecotec's VS - VY and Alloytec's VZ
  1. [VIC] vt-vz 3.9 diff gear, 42ib bosch injectors for LS1, 36ib l67 bosch injectors
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 27-01-2012, 10:34 PM
  2. [VIC] bosch 36lb white injectors and stock vr injectors
    Last Post: 31-07-2011, 05:22 PM
  3. Replies: 4
    Last Post: 13-11-2010, 08:16 PM
  4. [VIC] 6 x 36lb Bosch injectors - VS-VY Super6 injectors
    By BLC in forum Parts And Other Items For Sale
    Last Post: 13-03-2010, 04:45 PM
  5. [VIC] Wtb vt v6 injectors
    By FUN304 in forum Swap / Wanted to Buy / Trade
    Last Post: 10-10-2009, 09:06 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
