have a vk with injected 202 running on 5 cyl fixed that broken valve spring put car back together wouldnt idle but would run at 2000 + rpm any ideas what I have managed to do engine is running fine with carb on would also fire when started but just splutter out after a few seconds
would blocked injectors cause this
Yep, check all the plugs/leads/coil get the injectors cleaned.
is it injected or carb.
maybe you left of a hose, got two hoses around the wrong way or there is a vacuum leak at the carb base.
or if its injected maybe its got a leak between the manifold & tb or manifold to head.
you say it was running fine with the carb on, did you have a efi pump or low pressure pump with the carb
car was originally injected was running ok on five cyl had broken valve spring fixed valve spring put engine back together would splutter then stop but if you held throttle half open would start & run but only from 2000 +rpm double checked everything couldnt find any air leaks gave up put carby on mechanical fuel pump &disconnected electrics from electric fuel pump runs fine no probs
hey yea i just swapped my efi 202 into the toana and its doing the same thing! been trying for months to figure it out! injector cleaner didnt work. i also noticed it doesnt inject fuel into all the cylinders. my next guess is the efi computer aint workin propperly! anyone got an idea on prices for new efi computer?
