Results 1 to 9 of 9
Thread: injected 6 straight
    VP EXECUTIVE 3.8 V6 t700
    Jan 2005
    Armadale Perth
    Unhappy injected 6 straight
    Good sensible upgrade advice please, remap computer?, headrers?, full flow exhast?, polish port throttle body. Best improvement for least cash. Just want a little more towing torque please. Why did my VL start to die then stop, I know starter motor crook but it felt like fuel as it didnt miss or hunt just stopped from idle, who is the man to see, the rest of the old girl is great, had it one day and this happens, known car for 6 months and driven it before so smooth and reliable now this. Anybody please. jimrichards1964@westnet.com.au I am able to repair/replace 90% of stuff just want a starting point please.
    Regards Hannibal
    95 VS Vacationer
    Jun 2005
    VIC
    What exactly happened? Idle with no power or what?
    Start to die then stop? Or start to die then stop dying?
    evl Guest
    Jul 2005
    whats the timing like? could be way out.. id see about getting it running properly before you do any mods..
    Jan 2005
    Armadale Perth
    Unhappy burst heater hose, started fine
    Quote Originally Posted by killuminati
    then got home, started a few times stalled then started, then no start at all, killed planetry gear in s/motor, fitted new planetry and brushes too as nearly all gone, spins like mad and have great spark, its like injectors not opening, checked all relays,fuses and connections, dizzy cap dry, no cracks, reverse polarity relay might be dead as it has a diode in line. if no good sunday sending in the auto sparkies, compression good, not grabbing as if too far advanced, got me stuffed, happy to pay someone to sort it out without wasting money on parts that are ok. any ideas, thinking of getting moped.
    Jan 2005
    Armadale Perth
    Default rip it out
    Quote Originally Posted by evl
    rip it out ....... rb30det
    and fit what? whats good?
    Jan 2005
    Armadale Perth
    Default jimmy
    Quote Originally Posted by hotholdens.com
    when running right, is the pod cleaner and bosch coil an improvement, dont want to nuts just want it to be a joy to drive again, dont want to fluffy dice it, keeping stock, but upgraded stock, if you know what i mean, no cam, no sprts system, maybe remap spare computer for better performance/economy. will using moreys upper cylinder lube stuff up injectors /sensors, not my doind as its unleaded any way, thought it might be gumming up the works, before stopped running so smooth that you could NOT hear it running from inside the car, responsewas great, then started playing funny buggers. thanks for your reply. jimrichards1964@westnet.com.au if any positive ideas.ps alternator light used to come on for no reason before it stalled but sometimes just went out and kept running
    Last edited by jimrichards1964; 27-08-2005 at 09:51 PM. Reason: forgot important point
    Jan 2005
    Armadale Perth
    Jan 2005
    Armadale Perth
    13-15btdc it ran and idled unbelievably well, no hunting/vibration/hesitation nothing but it did try to change gears at rwrong time while cruising, g/box sensor crook? jimrichards1964@westnet.com.au
  1. My Injected 355 VL
    By VL 355 in forum VL
    Last Post: 31-01-2011, 05:39 PM
  2. Injected 5.0l
    By fitykemp in forum Swap / Wanted to Buy / Trade
    Last Post: 15-12-2006, 09:43 PM
  3. 308 and 304 injected
    By palmsvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-06-2006, 03:16 PM
  4. injected vh ???
    By bitch in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 07:42 PM
  5. Injected VH SLE
    By starkie85 in forum VB - VC - VH - VK
    Last Post: 02-10-2005, 10:52 PM
