Results 1 to 15 of 15
Thread: Can anyone diagnose my engine trouble?
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default Can anyone diagnose my engine trouble?
    Hey all.
    So the car was misfiring pretty bad so i took it to ultratune. They did a compression test and said cylinders 2 and 3 had low compression and said it was a blown head gasket. Pulled the car off the road and took the head off. But the gasket seems to be fine. No major breaks or cracks even? And now markings around the bores.
    So i currently have the head off and am looking at getting it reconditioned.
    I thought maybe the valves aren't shutting properly or something? Here a fer pics of the head
    2nd cylinder valve
    Doesn't look like the head has cracked anywhere. And the oil and water are both clean and havn't mixed.
    So before i get it reconditioned I'd like to know whats wrong with it
    Cheers for any help
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Is the cam shaft still in it?
    If so, thats why the valves are sitting open a little bit. If not they're farrrrked.
    VLC86's Avatar
    VL Calais
    Dec 2009
    yeah cam's still in. All i've done is unbolted the head and pulled it off and taken the photo
    Nov 2008
    Smithton, Tasmania.
    Okay, thats why the valves are open a bit.
    Are there any pistons that are especially cleaner then the others?
    VLC86's Avatar
    VL Calais
    Dec 2009
    Not really. Heres the best pic iv got. They all look the same as the one down the bottom
    What would cleaner pistons mean?
    Nov 2008
    Smithton, Tasmania.
    It can mean its had water going into the cylinder.
    Is there any scratching on the bores?
    Also drop the oil if you havent already and inspect it closely. IF the head gasket was okay (hard to tell, they don't always shit themselves completly) my only other thought is rings.
    VLC86's Avatar
    VL Calais
    Dec 2009
    Nope the bores are nice and smooth. All of them are.
    Ok i might try dropping the oil out soon and inspect it. What should i look for as i wont be doing it for a few days probaby
    Nov 2008
    Smithton, Tasmania.
    let it settle and see if silver rings form in the oil. If so thats a sign of metal in the oil. If there's anything more serious it'll be obvious.
    Aside from that, I'm starting to think you might have had a bad ignition problem or a slipped timing belt.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    id like to see better pics of the head it always to diffcult to tell from pictures in person always best. Cyl 2 looks like it has a rust water stain around the lip.
    Most common thing for vl heads is cracking and corrosion on water jackets causing water to get past under the gasket and into the cylinders (which will means gasket looks fine). If the heads cracked you wont see it till you pull the cam out as they crack 99.9% of the time in the cam tunnel
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    mate, i dunno but those head chambers look like a really nice colour to me. very little carbon, no white carbon, nice coloured valves...
    had you cleaned it? or is that how it came off?
    VLC86's Avatar
    VL Calais
    Dec 2009
    Thats how it came off ari.
    Im waiting to hear from a guy about when I can take the head in to get inspected. prolly next week sometime
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    i had a similar issue with my old skyline... misfiring and no compression on a couple of cylinders. gasket had gone on the water jackets allowing water to get into the combustion chamber. verified it by taking spark plugs out and cranking it over (water came out ).
    since you have the head off get it done and pressure tested. Make sure you check the block for flatness and put it all back together with new gaskets and you should be right
    VLC86's Avatar
    VL Calais
    Dec 2009
    hey thanks mate. I should be hearing back from the guy fixing it pretty soon. So ill know what went wrong soon.
    VLC86's Avatar
    VL Calais
    Dec 2009
    Looks to be the valves not shutting properly and hence losing compression. Getting reconditioned tomorrow morning and will be all fixed
    Thanks everyone for the tips.
  15. #15
    moon buggy
    Sep 2010
    moon
    Yep, cylinder 2 and 4 are both slightly open, no matter where the cam is (seems to be on the #1 exhaust) that is not right
  1. VT 5.0 Engine 'trouble'
    By Copafield in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2010, 10:09 PM
  2. Diagnose my engine
    By VSSECO in forum V6 Development And Modification
    Last Post: 06-01-2010, 03:39 PM
  3. how do i diagnose engine probs? and what are "codes"?
    By zumanity in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2007, 12:39 PM
  4. Vr Engine trouble..
    By aLxVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 03:01 PM
  5. Engine Trouble...
    By DenchY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2005, 01:32 PM
