Results 1 to 7 of 7
Thread: RB30 into VK Calais Conversion
    VK Calais
    Feb 2011
    Default RB30 into VK Calais Conversion
    Hi,
    This is my first post... I'm working on installing an RB30 engine and 5-speed manual gearbox into a VK Calais (my son's first car project). Can anyone please advise how we should go about modifying/installing the exhaust system?
    In particular, where is the best place to locate the catalytic converter, assuming we're going to use a set of extractors in place of the stock cast iron RB30 headers. We're also thinking about a 2.5" inch exhaust system from the cat back.
    I know the VL Commodore floor pan on the passenger side was modified to fit the stock cat, so I'm interested in how others may have fitted the cat into the VK... without taking a big hammer to the floor pan.
    Example photos would be great, if available.
    Thanks in anticipation.
    Regards,
    Nick
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    Pub247's Avatar
    Pub247 is online now Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you might be able to get it to hang abit lower but im fairly sure it bolts up from what i remember the floorpan was modified for transmission clearance
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    On my VK with a V6 the cat tucks up and the rear end flange is inline with the handbrake boot under neath, there is a little section there where it fits nicely on mine. have a quick look under yours and you should see the spot.
    VK Vacationer Waggon
    Aug 2011
    Sth East NSW Coast
    Hi i have had a rb30 with 5 speed box in my vk for the past 11 years the best thing i ever did i used the vl extractors and cut the flange off the end and had a pipe welded and an aftermarket cat welded to pipe then 2.5 inch exhaust out to the rear .
    Not having the flange on the cat ment that i didnt have to bash the floor in also if memory is correct i did have to lower the rear gearbox mount when i modified it to make clearence for the extractors from the floor i assume you have fitted the engine allready
    Sam........... RB30/20
    Aug 2011
    Sth East NSW Coast
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    Cat would be least of the troubles
    These things are tiny
    3" High Flow VENOM Metal Cat XR6 VL Turbo Skyline R33 | eBay
    Can get all diffrent sizes
  1. rb30 vk conversion
    By Cal-a in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-03-2011, 12:29 PM
  2. My VB - RB30 Conversion
    By madvb in forum VB - VC - VH - VK
    Last Post: 07-08-2010, 01:32 PM
  3. Vk Rb30 conversion
    By benjiaka in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-07-2009, 09:43 AM
  4. VB - RB30 Conversion
    Last Post: 31-10-2008, 10:04 PM
  5. RB30 Conversion
    By eko in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-10-2008, 07:29 PM
