can anyone give me tips on how to connect my 5 inch tacho to the standard tacho dash ???
Maybe try start the thread in the right place and do a search theres a whole thread on tachos.
VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
yeah ns figured that out last night im new to this site so give me a break
Wasnt trying to be rude or anything mate just letting you know. If pull out your dash cluster where the std tacho bolts on the cluster theres three bolts. Tops ground, middle is the tacho signal and bottems the power. For your lights just use the light swich. Thats for the L2 cluster with the tacho already in it. If you get stuck just ask.
Hmm tacho.
I think hes putting it in a manual i mean i hope hes putting it in a manual.
nothing is wrong with tacho dash buts its in a manual burnout car and i was thinking of getting rid of hole dash and makin a lil custom one up
thanks for the tips
if your takeing out the whole dash just use the wires of the plugs that go into the cluster its all labelled on the back of the cluster.
thats wat i thoght but they ant working >![]()
you havent unpluged any of you loom or anything have you. well since its a burnout car just run the power to the fuse box tap into power after its fused. then just earth it somewhere and run the tacho signal wire to the engine bay.
