Results 1 to 4 of 4
Thread: Will the Air Flow Meter from a VL work on a EI VK
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    Default Will the Air Flow Meter from a VL work on a EI VK
    I am looking for a way to replace the unreliable old vane AFM in the VK, and was wondering if the VL hot wire style will work on the VK compter. The VL unit fits and all the wiring is somewhat similar, (the plug is th same, both being bosch products). I just want otherpeoples opinions/experience before i fire up the engine.
    cheers
    flow=go Guest
    VZ Exec. 3.6
    Oct 2005
    VY SS A4 WAGON, EH UTE
    Oct 2005
    Newborough, Vic
    Thumbs up Megasquirt it !!!!!
    Check out this site :- http://www.msefi.com/
    Build your own EFI computer. Learn a heap about electronics, without having to be an engineer. This site has the best manual I have ever seen for a DIY site. Wire it up with a VK connector so you can swap it with the VK EFI analog unit. Then you can throw away the craptacular vane airflow meter. Megasquirt uses a MAP sensor. Wire up a commodore oxygen sensor and get better economy than the VK ever had. Once this is all done, use the Megasquirt to control spark as well.
    You know you want to.
    Rock Lob
  1. Vt air flow meter
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:22 AM
  2. Air Flow Meter Help
    By Statesman94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 11:01 PM
  3. LS1 air flow meter
    By I LIKE COMMODORES in forum General
    Last Post: 01-09-2005, 02:43 PM
  4. Air flow meter...
    By stylen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2005, 02:03 PM
  5. vl air flow meter
    By psi berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-06-2005, 09:07 PM
