Results 1 to 25 of 25
Thread: aircleaner modifications
    1982 VH SL/X 6cyl 4spd, soon to be a Mild 253
    Oct 2005
    Port Pirie, South Aust
    Default aircleaner modifications
    just wondering if any 1 knows of any mods i can do to my standard aircleaner. eg, chop off the throat/snout thingy. drill holes in the bottom. just so it can get some better air intake/flow
    Oct 2005
    also could i try forced induction strait to the aircleaner or would that be bad down low and off of the line
    Oct 2005
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Oct 2005
    VR V6 S2 ute
    May 2005
    Alexandra, Victoria
    Default Air cleaner mods
    Mod the inlet to get cold air to the carb as hot engine bay air kills peformance. Don't think there's anything illegal in getting fresh air !!
    Good luck,
    Slik
    VR V6 S2 ute
    May 2005
    Alexandra, Victoria
    Mod the inlet to get cold air to the carb as hot engine bay air kills peformance. The air cleaner on the 2.85 litre engines had a factory CAI from memory. Don't think there's anything illegal in getting fresh air !!
    Good luck,
    Slik
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    Thumbs up chrome air cleaner
    i just made up a pretty sexy air cleaner yesterday usinga chrome hub cap off a HR for the top, and the base plate off the stock commodre varajet air cleaner. Looks good with the chrome rocker cover.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    VL
    Jul 2005
    SA, Mount Gambier
    Try somthing diff, get some carby spacers, nice chrome k&n aircleaner and poke her through the bonnet. - this is not lagal in sa.
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    my camera is stuffed at the moment but when its workin ill show ya.
    im hungry
    Goon's Avatar
    Feb 2006
    GC. QLD
    VL
    Jul 2005
    SA, Mount Gambier
    Nah no pics. but i THINK a series of old falcons came out wid offset hornet style air scoops?? dunno u have to google it lol.
    Oct 2005
    well ive been seriously thinking about geting a bug catcher with the 3 butterflies. gotta admitt dat would look pretty cool. but dunno what the cops would think tho. just a bolt on thing to sit on the carb, not a supa charger or nutin. just need to think of a way to centre it other wise i think it would look funny. does anyone know how much these bugcatchers cost?
  15. #15
    vk wagon
    Aug 2005
    hey tukrbox, i just put some bendy foil tubing from the snout of the air cleaner down between the battery and radiator and made it so it sat in the gap on the front bumper.
    i surpose you could call it forced induction???
    it works a treat!!!.
    if the cops say its illigal i can easily take it off on the spot.
    shane.
  16. #16
    Oct 2005
    not quiet forced induction but would help out alot still. is there n e way i could incorperate my pod filter into the induction?
    could u take a pic of how uve set it up?
    Jake87:
    im also still waiting on these hubcap aircleaner pics........
    tukrbox
  17. #17
    effected79 Guest
    Default effected79
    I have a vl exec and recently added on a pod filter, does anybode know if these work better than a kand n panel filter?
  18. #18
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    panel filter is far superior to a pod. the panel is not even restrictive its the AFM mesh's that are the most restrictive part so remove the rear AFM mesh and use the k and n panel.
    ========My Statesman 20's Mafless and 3.9's========
  19. #19
    VL Berlina
    Oct 2005
    valiant aircleaner, can't remember which one, but look around. apparently higher flow
  20. #20
    VC SLE track car, 10 sec VU Ute
    Jul 2005
    I have been told that you can cut short the standard snorkel and an AU falcon intake pipe will fit neatly (pop rivit on) to allow you to draw air in from behing the headlight like the Brocks had.
  21. #21
    Jul 2004
    you can bolt the top of the aircleaner on upside down to get more air flow....
  22. #22
    VS Commodore Acclaim
    Jan 2006
    Quote Originally Posted by shamus
    Turning lid upside down does nothing other than make more induction noise. More air can get into the can but more air can get out also. A snorkel or hose to a cold air source works much better.
  23. #23
    Goon's Avatar
    Feb 2006
    GC. QLD
    I've had the snorkel and hose + metal pipe idea for a blue 202 "been looking at the desgins from other cars" but this would require to cut a certain amount off the air cleaner nose and move the battery into the boot...
    If a create a prototype ill ket ya's know
  24. #24
    Goon's Avatar
    Feb 2006
    GC. QLD
    I've got another idea it starts on the left hand side of where the grill should be, next to the radiator.. The motor fan would have to be removed and replaced with thermo's as the hose could get caught up then cut up!
    Will post some pics soon as i said before
  25. #25
    VR V6 5-speed
    Jun 2006
    how about if you turned the aircleaner upside down and put a small scoop above it through the bonnet?
    you could block off the original snorkel.
    there would be plently of cool air coming in.
  1. VZ SV6 - Modifications
    By Blonk in forum V6 Development And Modification
    Last Post: 19-01-2012, 08:10 PM
  2. VE V6 Modifications
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-10-2007, 05:24 PM
  3. modifications
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2006, 12:22 PM
  4. modifications
    By executive_power in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2005, 11:45 PM
  5. Modifications
    By hoof in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2005, 10:24 PM
