Results 1 to 21 of 21
Thread: RB30e ECU confusion
    Krullos Guest
    Default RB30e ECU confusion
    Can someone tell me if there is a difference between the standard computer from a VL 3ltr and the computer from a VL GTS? I've been told by some people that GTS computer is tuned to give the engine some more grunt, but told by others that all the computers are them same for 3ltrs... Can anyone answer this once and for all?
    Krullos Guest
    KCElectronics Guest
    Default Whats a VL GTS?
    Whats a VL GTS? the RB30E (N/A) has 2 ECU's 1 x Manual 1 x Auto! and the RB30ET (Turbo) has 1 x manual and 1 x turbo, so there are 4 in total
    NO Value putting a Turbo ECU on to a N/A the F/I maps are not compatable
    Chuckie
    Manwal VN Guest
    Whats a VL GTS? I know of the R31 GTS's, the GTS1 had a standard computer (the white ones). The GTS2's had a plugin computer cause of the cam in them (the red ones).
    KCElectronics Guest
    Default Wrong Forum!
    Yes I think you are on the wrong forum? you should be talking to the Skyline guys!
    Chuckie
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i've seen vl gts bodykits but don't know the mechanical differences. he may very well be on the right site, just no one knows the answer to his problem.
    Krullos Guest
    Quote Originally Posted by bangers
    Here is an example of a VL GTS...
    http://www.gpforums.co.nz/showthread...oto=nextnewest
    VS BT1 V6
    Nov 2004
    Default Ok
    Just NZ BS - Prob the same as a stock VL with a GT badge .....
    Want a GTS VL , Glue on the Badge ....
    Skyline made a hotter ver , so find a genuine Nissan ...
    Matt
    95VS V6 BT1 - CAI - K&N airfilter - Lukey Headers - REdback system - FIT Rockers - PowerChip Gold 98..
    pumba's Avatar
    pumba is offline OMR346
    VZ SSZ
    Jan 2006
    brisbane southside
    vl gts??? never bloody heard of it. as mattk said, probably just some wally who slapped on a gts badge and sold it to some sucker lol. and on that link, it says the vl came out with a rb20 option.... since wen did that happen??? never bloody heard of a rb2o vl (stock) unless ppl done the conversion them selves lol
    Krullos Guest
    The 2ltr RB20 option for the VL only came out in New Zealand, and is quite common over here....
    I have now been told by a mate that "the only differance between the GTS & the standard VL is the GTS has a skyline series stage 1 cam aparently & sports suspension"
    Krullos Guest
    It appears they only came out in NZ? Though everyone has different ideas regarding what the difference from normal was....
    http://oldholden.com/?q=node/2915
    There's also someone at "calaisturbo.com.au" living in Auckland that claims to have a '87 VL GTS 3.0 n/a manual
    Grantis1976 Guest
    Someone mad the same suggestion to me acouple of days ago, but it was to replace the standard ecu with that of a Skyline GTS.
    After laughing alittle too hard, I asked the guys in the workshop across the road from my work, and they say yes, but not worth the dollars.!
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by Krullos
    some tosser just glued on a badge in that pic. the GTS kit i saw has a particular bonnet scoop unlike the Grp A and walkingshaw etc.
    VP Executive R-spec
    Jan 2005
    If anyone has the binary/rom images for the NA RB30 and the turbo could they send them to me, all the old sites that used to have this stuff seem to be dead. I wouldn't mind seeing if I can convert the NA computer to turbo specs like that darkhalf dude used to be able to do
  15. #15
    vlrb20
    Aug 2009
    VP Executive R-spec
    Jan 2005
    Thats was years ago by the way you can turn the NA ecu's into turbo ones, easy as
  17. #17
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    The vl walkinshaw (Proper not replicas) from the factory had a different ecu which only has an extra plug so you can plug a laptop in and tune like vn onwards and it was also there to read the diagnostics not like the standard one where you have to do it manually with the leds but the standard vl's dont have that ie; calais, berlina etc...
  18. #18
    VP Executive R-spec
    Jan 2005
  19. #19
    Nackerz's Avatar
    Jul 2009
  20. #20
    VP Executive R-spec
    Jan 2005
    Yeah because they aren't a Nissan ;P so there's no Nissan ecu in them. They got the GM stuff
  21. #21
    Nackerz's Avatar
    Jul 2009
    are thought there was something going on there! lol
  1. RB30E Performance chip
    By Flak in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2012, 05:05 PM
  2. rb30e converted to rb30de?????
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2009, 01:16 AM
  3. Vl Rb30e to 308
    By TURBO_VK in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2007, 07:25 PM
  4. how much hp will a standard rb30e take??
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2006, 06:43 PM
  5. Rb30e F.s
    By coolvl in forum Parts And Other Items For Sale
    Last Post: 31-08-2005, 11:07 PM
