Results 1 to 15 of 15
Thread: how can i tell the cube of my engine?
    2o2VB Guest
    Default how can i tell the cube of my engine?
    hey i have a 1979 vb wif a red motor i was told the otha day it was only a 186 but wen i brought it i was told it was a 202! can ne1 help me out
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    Passenger side of motor, size is cast in the block. Look from underneath the car.
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    clixanup is offline Has Left
    Jan 2004
    Quote Originally Posted by Pretender
    Shouldn't need to look from underneath. It should be pretty easy to spot with the aid of a torch.
    Hector martinez Guest
    it would be right there behind the alternator or check the engine number if it starts with 'QL' its a 202
    Vs clubby daily driver & vb project car
    Jan 2006
    im pretty sure the vb red motors had capacity in litres cast into the block, not cubic inchs as like the early motors
    Jan 2004
    Quote Originally Posted by hot308vb
    Mine had '202'. Original motor. It was an early one though, built October 1978. Maybe the later ones had that.
    Edit: But the air cleaner had "GMH 3300" on it.
    Grantis1976 Guest
    fraz9 Guest
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    my blue one is 173.
    look on the block, its cast in big numbers, cant be missed
    Rob
    Grantis1976 Guest
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    By memory it should have either 3.3 being a 202 or 2.8 being 186 on the side of the block behind alternator. its not that hard to find.
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Just for anyone interested. These are the standard sizes for the Holden designed sixes
    3.3 = 202, 3.0 = 186, 2.93 = 179, 2.85 = 173, 2.63 = 161, 2.44 = 149,
    2.25 = 138, 2.15 = 131
    ci x 16.387 064 069 = cc or cc/16.387064069 = ci
    Some blue motors were marked in CC others in CI but all (original) black motors were in CC (expressed in litres ie 3.3).
    Never
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Then if u still can't see your number, get a can of degreaser
    ps. maybe you have a 202 with a 186 head?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    EF Almost Turbo
    Jun 2005
    so a 2.8 is 186.. whats the starfire then? 100?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
  15. #15
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    3.0 is a 186. Starfire = 115ci (1900cc)
    Never
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. engine light, engine cut out
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:10 AM
  3. Engine + engine bay colours?
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 02:06 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
