Results 1 to 5 of 5
Thread: 202 Performance Engine
    graeme308 Guest
    Default 202 Performance Engine
    Hey guys
    Just after a bit of help with my new engine and which way to go.
    i have a black 202 with a T5 borg worner. 2 1/2 inch lukey with extracters
    i was thinking about boring 30 tho using ACL flattops pistons the same as the HQ racing cars
    A crowcam 40/90 or bigger
    standard oil pump
    acl bearings
    ignition from a auto motor 202
    i have got the head done and it has bigger valves and bigger valve springs and it has been sorta ported. by this i meen the ports have been cleaned up and de bured aswell as made a bit smoother.
    Yella terra rolla rockers
    webber 34adm duel throat
    lightened fly wheel
    regrind on crank
    and full engine balance
    just wondering what u think and any changes or suggestions that u guys have. Also if u guys no what sorta power i would be looking at.
    cheers
    Graeme
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Add some extractors/headers and thermo fans mate and she will be screaming down the road !
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    graeme308 Guest
    yeah already got a set of pacemakers on it with a lukey 2 1/2 inch sports
    Goon's Avatar
    Feb 2006
    GC. QLD
    If you got the cash you could lose the manual fan and go with thermos, maybe VT twins if your feeling rich, plenty over ebay..
    Atm i'm installing a 16inch as the main and a 14 on the front as a backup, the car hasnt moved much so i don't have real good results :P The cooling system will be differrent but your RPM will increase.
    If you do decided to go thermos dont forget to make sure u have a thermostat switch with ur thermo setup.
    hinterland's Avatar
    hinterland is offline commyvt
    vt sed turbo
    Feb 2005
    put 3 webers on it them 12 port heads love em.
    vt super6
    pump action turbo kit
    dry sumped
    few mods
    totally shaved
  1. 202 Performance engine
    By graeme308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-05-2006, 07:29 PM
  2. vp engine performance
    By reggie_c2005 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2006, 12:07 AM
  3. What do you do to increase performance on V6 holden engine
    By turkeychicken in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2005, 03:00 PM
  4. Performance Options for a VB engine
    By ozidata in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 08:47 PM
  5. removing thingy in engine to gain performance
    By stinky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2004, 01:04 PM
