Results 1 to 4 of 4
Thread: Need opinion on crank Shaft
    VK 3.3
    Apr 2006
    QLD, Regents Park
    Default Need opinion on crank Shaft
    Pulled crank shaft out the other day from a 202 black. Bearings were pretty worn and some had white metal and brass stripped (close to melting).
    Theres a few blemashes on the crank nothing to bad just thinking of goin over with some really fine emery paper.
    "Any opinions would be appreciated"
    I love my bucket
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    For the money it will cost get 10 thou machined off the crank shaft & bu 10 thou bearings for it
    cheers
    Scott
    VK 3.3
    Apr 2006
    QLD, Regents Park
    10 thou been taken off already
    also the its been bored out to 60 thou
    I love my bucket
    VZ SS
    Jun 2005
    I wouldn't worry to much about 0.010" undersize. See what undersize bearings you can obtain for it. I built a 186 with 0.060" undersized mains 0.025" rods and it is still going fine 25 years later. What you need to worry about is the finish and roundness of the journals. They must measure the same all over the journal. If they have any groves apparent on the mains or rod journals don't use it without grinding or linishing as this will reduce it's life considerably. It sounds like it has been running without oil or the mains were put in to tight. The only reasons i will normally throw away a crank is the rear main seal or the thrust faces. There may be further damage inside the block. Did it spin any of the bearings? Are the cam bearings OK? Are the rods OK ?
    It's been a while since I have had a crank done but it may be cheaper to get another second hand unit in OK condition but this may still need grinding. Bite the bullet and get it reground and at least you know it is good. Make sure your block is clean and all the oil galleries are clear as this may have been the reason why the bearings went.
    Daza
  1. Second Opinion!?
    By 1994 CoMMy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2007, 10:42 AM
  2. Your Opinion
    By arty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-04-2006, 12:44 AM
  3. Bent Crank Shaft
    By brey9186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 10:52 PM
  4. Harmonic Balancer / Crank Shaft Pulley
    By knight97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2005, 07:38 PM
