at the moment i have cold air induction with k&n air filter, extractors 2.5 inch exhaust, advanced cam timing. wat other performance things could i do? without getting a turbo as i am under that new restictive law where i cant drive turbos or anything like that.
bigger leads like egale 8mm or 9mm, camshaft upgrade, headwork, ecu upgrade, diff work, not much more that can be done for a na 6 bsides full rebuild with new pistons and all
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
yeah i got the 9mm leads to
turbo, nitrous or supercharger
yeah i got one of those restricted licenses and not allowed turbo etc. thats y i want to know anything at all that can make me go fast as possible.
XF thottle body...
Twin Hyclones...
Bigger injectors and a higher capacity fuel pump...
Port & Polish...
New camshaft (I'm looking at Craine.. looks good!).
Tried advancing the cam timing?
he already has. and i wouldn't bother with the XF throttle body or hiclones.Originally Posted by Marco-EFIVL
if you want more fun then put a manual in it.
whats advanced cam timing ?
open the head up. put a cam in. and a CDI setup with 10mm leads would get it cracking.
his car already is a 5spd! oh and every peformance place i went to said the same thing about an aftermarket cam... the dont like em, nissan got it right the first time... agreed about bigger injectors and high pressure fuel pump... and NO kev im still not tellin ya what my secrets were with my cream vl...some things are better off left in my garage hahaha![]()
Going where no late model stato/caprice has gone before.... GAME ON!!
hi. i have a vl 5 speed as well but also have not much money!! Iam under the restrictive laws also. I would like to have a quick vl as well but i want to spend as little money as possible. what can i do to my car???
^plz email camerons1@hotmail.com
Thanx
yes nissan got it right the first time for a stock motor, not one with work.
If you do some head work like port and polish and valve, raise the compression, cam and run a better plenum, cooler, and better flowing exhaust and with a decent computer and tune, you will still push some power through a NA motor.
i'm don't know the exact power you would get but i'll be guessing round the 200-250 kw mark
Soon to be back on the road, Turbo VG.
