Results 1 to 4 of 4
Thread: standard head gasket vs copper
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    Question standard head gasket vs copper
    I have a RB30ET which i just rebuuilt the motor on replacing the original gasket with a copper head gasket and it is mixing oil with coolant in the motor so i am saying it's leaking through the head gasket.
    I followed the torque specs in the gregories book, is this only suspose to be for the standard gaskets, is there a different torque spec/ sequence for a copper head gasket?
    Does anyone know the exact procedure and specs for each gasket?
    What is the boost limits for each gasket?
    I will be running 1 bar or 14.7 psi of boost.
    Thanks.
    Colin.
    Soon to be back on the road, Turbo VG.
    hinterland's Avatar
    hinterland is offline commyvt
    vt sed turbo
    Feb 2005
    Quote Originally Posted by cohn View Post
    Thanks.
    Colin.
    running copper gaskets with high boost is a must as they are bullit proof and there preaty well a pain in the arse when it comes to leaking as mine were also, i had bit of problem with but sorted it by useing 3bond to seal them with and anealing them again .lightly wave a soft oxy flame over them untill they change colour and cool them down it doesnt matter if quenched in water as it doesnt make them hard.lightly scrub them with scouring pad and clean of with metho and apply 3bond to both surfaces of gasket and assemble tenshion down to all but few pound less of correct settings and leave overnight re tention to right settings and you wont have any more probs.and they will handle as much boost as you want at them .
    vt super6
    pump action turbo kit
    dry sumped
    few mods
    totally shaved
    cohn's Avatar
    VN Calais Turbo
    Nov 2004
    Penrith
    did you replace the gaskets or just use the one that was leaking?
    is holymer better then 3 bond, and retansion? do you mean loosen the retighten or just go over tyhe bolts and hot or cold motor?
    thanks.
    VP Executive R-spec
    Jan 2005
    You dont need to replace it, just do what hinterland said. I used to reuse them on my motorbikes for ages, I'd allways be inside cooking gaksets on mums oven
  1. Head gasket
    By cohn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-01-2010, 02:53 PM
  2. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  3. standard head gasket vs copper
    Last Post: 04-07-2009, 01:17 PM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. Head gasket
    By sleekism_69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2004, 02:10 PM
