Results 1 to 3 of 3
Thread: Head mods
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    Default Head mods
    Just wonderin what others ideas about head mods are, first of what will the major difference be between the low and high compression blue heads be besides the compression and would it be worthwhile polishing the chamber area aswell as the ports
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Low comp heads are an open chamber design which will breath a bit better than the High comp head but you loose a bit of power down low in the rev range. Low comp heads also use a bit more fuel. For the ports, just use a manifold gasket as a template and open up the inlet ports to the same size as the holes in the gasket. Take your valves out and round off the bottom of the port where it goes into the valve bowl area under the valve then grind your valve guides so they are a bit thinner, then get a good 3 angle valve grind.
    VC,VK, VN
    Feb 2007
    Black/blue heads dont need too much work untill you start getting serious, they'll flow around 190 horsepower anyway. I'd go for the 3 angle grind for sure.
    I wouldnt polish the chamber but i'd smooth it out, go for around 9.5:1 compression.
    Use a Crow 35667 cam with that moderate head work.
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. VS Mods - Help me out
    By Ewok in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 07:11 PM
  3. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  4. 5L head, cam and inlet mods
    By vtss5spd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 07:14 PM
  5. VK MOds
    By Holden_Mechanic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2005, 02:46 PM
