Results 1 to 11 of 11
Thread: 5 spd conversion
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    Default 5 spd conversion
    hows all,
    i want to throw a toyota 5 spd into my vc 6 cyl, so i am after any suggestions on the matter, basically i want to know which one is best and what conversions i need to do to the box and crossmember also clutch plate, also is it much of a pain in regards to time e.t.c as it will be a weekend job hopefully which for me is generally only one day.
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    Sep 2005
    VC Commodore
    Sep 2004
    Bundaberg qld
    probably is worth more than the car, but there is reasons for it's existance, hence why it is being kept alive and improved
    spauldj308's Avatar
    spauldj308 is offline S Pack Man
    VR S sedan 5L, VSII ute
    Oct 2005
    Hobart, TAS
    If you want it, keep it! A celica 5 speed should suffice, you could chuck a Supra box behind it but it wouldn't be worth the extra cost. Castlemaine rod shop make the necessary kit to convert I beleive, http://www.rodshop.com.au
    VR II S sedan - Genesis Blue - Cammed 304 - T5 - 19's - Weekend warrior
    VS II S ute - Diablo Red - V6 - Getrag - Daily Hack
    Jul 2006
    I think the Celica will hold just fine, I had a celica 5spd behind my 100RWKW Blues 202, in a VH track only car, so it only got abused & it held up just fine.
    & I only paid $100 for that box. its all the conversion parts that ad up, Belhousing, clutch plate, speedo cable & cross member. I had to make a spacer to run a std holden clutch cable.
    They are a good box. nice smooth shift.
    Red VH track car project 308
    White VX Berlina Gen3
    VC Commodore
    Sep 2004
    Bundaberg qld
    Sweet, thanks for the info, i had heard that the celica was a good box for it but u can never be to sure, i figured i would have to do a fair bit of mod to fit it in though, it may seem silly to keep it on the road and spend this amount of cash on it but when you live in regioal areas you get sick of waiting for upto a week plus for parts to arrive, atleast with the older commodores i can go to any wreckers or spare part mobs and find the parts straight up
    VN Executive V8
    Jan 2007
    Make sure its the steel cased celica box. I used one behind a mild 202, in a FC build I did. Went great. Used Dellow Automotive conversion kit. Fitted easy in a day with a mechanic mate and a carton. If your going for a performance 202 the supra is a stronger box, but depends what your after?
    Marco-EFIVL's Avatar
    Marco-EFIVL is offline Now driving R34 GT-T taxi
    Nissan Skyline, R34 GT-T (RB25DET NEO) sedan
    Aug 2005
    Perth Balcatta/Hyden (Wave Rock)
    On tranny's, would a Skyline 5sp suffice for an Auto-Manual conversion? It is a different tranny than what came in the stock vl manual, or same?
    vc 202
    Jul 2005
    Default gearbox info
    hey put a toyota dyna clutch behind it heavyer then a standered toyota clutch did it in my lj torana and goes great guns
  1. Gas Conversion
    By mrextreme in forum General Discussion
    Last Post: 14-07-2011, 01:00 AM
  2. F/S V8 5 spd conversion
    By Devils_VK in forum Parts And Other Items For Sale
    Last Post: 15-09-2008, 05:35 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. VP V8 -> V6 conversion
    By Kingo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2007, 12:19 AM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
