Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: 202 advice.
    vh sl/e
    Feb 2007
    Exclamation 202 advice.
    gday, im lookin to do up a 202 blue or black motor and was wondering what stores around ipswich/brisbane area would help with the modifications? being the first time modifying an engine i have little to no idea where to start.
    can i just ask a mechanic to do work on an engine for me? or do i have to buy parts and then have them put on?
    also can anyone give me a rough price of working a 202 (cam, head, holley, headers, exhaust, good block.)
    VN Executive V8
    Jan 2007
    A performance 202 will not be cheap. Cheap compared with a V8 but still costly.While there are plenty of parts around at good prices if you don't have the know how to throw it together the labour involved from the mechanic will blow the price out.
    Look for a 202 for sale as a complete engine which has already had the work done, i.e. yella terra head, YT rockers, flat top pistons, steel crank etc. This will save you a heap on building it yourself. Buying 2nd hand
    you'll still be up for $2000 - $4500 for that engine but thats cheap considering the cost of building one to that performance level.
    Talk to people who have built hot 202's before as they'll be able to tell you the do's and don'ts with first hand knowledge.
    Can't help with mechanics up your way sorry.
    Good Luck with it.
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    Quote Originally Posted by edgeyvn View Post
    the dont is "dont do it"
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Do up a 186 instead, they rev higher and produce more torque. Paint it blue, cable tie some hoses around it, police probably won't know any different.
    1983 VH SL 3.3 Litre 5 speed, 2002 VY Executive
    Feb 2007
    Burnie, Tasmania
    gday im new to the forum, today i bought a VH commodore (my first car) which has a blue motor, it has a burnt out valve in the 5th cylinder(not my fault), I was wondering (since we are on the topic of doing up 202's) does anyone know how much a stainless steel or titanium valve set will cost, im not looking for installation cost either because i can do that myself. I seen a Red motor once for $50. those are good for first timers
    Sep 2005
    Quote Originally Posted by Not_An_Abba_Fan View Post
    actually 202's make more torque due to having a longer stroke
    and blue motors also has xu1 style conrods and a counter weighted crank
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The torque curve is sharper then, they rev quicker and get to maximum torque faster. They produce the torque better than the 202 is what I should have said.
    Feb 2007
    Burnie, Tasmania
    VC,VK, VN
    Feb 2007
    I'd use the black 202 over a 186. Superior bottom end and the black head is comparable to the old 9 port stage three yella terra.
    The best bang for buck is forced induction, ie. supercharging.
    The Toyota blower setup from the Castlemaine rodshop (though others are doing it now as well) is a great deal at around $1800.
    I'd include a stroker kit from bryant engineering, you supply the black crank, and it takes out your 202 to 249. Its a complete kit using hemi rods new quality pistons, bearings etc for $2000.
    With just a mild cam this combination pulls like a train throughout the rev range. ie, no need to flog its tits off.
    Sep 2005
    Those chargers from crs wont keep up with a 3.3L engine and also the charger is mounted upside down
    your best beat is the turbo route buy a complete garrett strata kit and have some fun with that if you want to go efi you will need everything custom made and the intake manifold will let the whole setup down
    Stoke it are you talking about a modified ford 221 crank? if so they only stroke it to 234
    VR commodore,VP 5.0 calais, 2x59 FC,
    Apr 2005
    what are you pepared to spend.
    black is the best but it has nasty smog gear witch should be hooked up to be legal, the oldest you can go in a VH is a blue motor(173 or 202)
    if you want a mild hottie read the street machine grunt hunt.
    Advantages of a red are a lighter crank that can spin up quicker and less or no smog crap.
    The lighter crank is also a disadvantage as it isnt as smooth without counterweights.
    if you cant build any of the motor you should try and find a fresh hottie for sale.
    i spent 5k at the engine shop on my holden six and still have to put it together, i also supplied alot of parts on top of that so if you want it to be fast you need to save hard, with the availabillity of cheap factory v8 commodores it isnt really worth it, maybe if it was a LC-LJ or something earlier it would be worth it.
    you can also get efi 3.3's for around $300 now.
    Sep 2005
    Like above it costs alot of money to build holden 6's with absolute no gain out of it there old motors and cost way to much to build but if i was to build one it would be
    stroked
    twin cam
    blown (big gm blower)
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    As said. A holden six is piss easy to build. Machining is cheap so are the parts. If you have the know how it's far worth it then a conversion but at the end of the day nothing replaces cubes! I have to say tho you get a better feeling raping the arse off a 5ltr with a 20+ yr old 3.3ltr straight six
    VX11
    Mar 2007
    Mate,If you want a basic setup for a daily driver and remain reliable have the block bored and fit a set of ACL Race Series Pistons as fitted to the HQ racers.Find a secondhand yella terra head and use a mild cam with extractors.This will give better throttle response and a gain in power over standard without going overboard.
  15. #15
    VC,VK, VN
    Feb 2007
    No mate thats a pro stroke kit. im saying Bryant Engineering. apparently Pro stroke havnt had any problems with the ford crank but im just not into welded cranks.
    I actually have this setup and it works fine, doesnt keep up? Yes it does.
  16. #16
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by Dan355 View Post
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  17. #17
    Sep 2005
    Quote Originally Posted by stroke it View Post
    yeah im not a fan of the welded cranks either but they have been around for some time
    you will find the charger is a little to small and if you upgraded to a SC20 (off some landcruiser or something) you would gain a fair amount of power as you would be able to get more up in the rev range IMO
  18. #18
    VC,VK, VN
    Feb 2007
    Quote Originally Posted by Dose Pipe View Post
    Yeah back to back i would get more power from a SC20 for sure.
  19. #19
    Sep 2005
  20. #20
    VC,VK, VN
    Feb 2007
    and also im not a fan of the teflon coating on the rotors.
    yeah look if you thrash the guts out of it yeah, but the seal will go usually before that happens.
    Honestly/ the toyota blower isnt designed for horsepower hero's, in my situation it works fine and i have good strong torque up to 5200rpm but i dont cane the tits off it.
    If you want all out, spend the cash, turbo charge it and wring its neck.
  21. #21
    Sep 2005
  22. #22
    VC,VK, VN
    Feb 2007
    Some just like thier old 6's but hear you, it cost some serious hard earned to get old technology competitive with whats around these days.
    Bung in a serious V6 and youll have all the power you need to wrap yourself around a stobie pole with.
  23. #23
    Feb 2007
    Burnie, Tasmania
    my Blue motor's fan belt squeals when i get to 3000rpm, it's new and it's done up to the right tention, it only happens when ya hit the accelarator pedal too quick, is this normal?
    F.O.R.D
    Forget Out Running Datsuns
  24. #24
    Sep 2005
  25. #25
    VN S Pac VH SL/X
    Jul 2006
    ok this is offtopic but i dont want to start another thread on the I6. I have in my possestion an LJ Tori which is my first project car. Bought it for $600 and came with XU1 carbys, xu1 brake setup, xu1 diff and a m21 4 speed. Question im wondering is. It has a 173 in it at the moment but im wondering if I should go red 173, 186, 202 or a black 202. if i get any red motors the triple strombergs will be bolted onto it but if i get the black itl add complications such as ADR and EPA etc etc. So any suggestions?
  1. bit of advice
    By pitt88 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-04-2007, 05:47 PM
  2. Vx advice
    By VRV666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2006, 10:22 AM
  3. VG Ute need advice
    By sumna in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 06:13 PM
  4. Need Advice
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 10:55 AM
  5. Some advice please.
    By trucker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 07:54 PM
