Results 1 to 19 of 19
Thread: VL turbo conversion
    VSO.38 is offline JCCCQ Member
    97 S2 VS Acclaim
    Oct 2006
    Ipswich, QLD
    Post VL turbo conversion
    Hey guys, I've got a Vl motor and I'm considering pulling the motor down it to check its condition and rebuilding it with the intensions of putting a turbo on it, can the stock N/A bottom end be used with a turbo or do I need to rebuild the bottom end with something a little stronger???.
    Any help would be appreciated. Cheers, TJ
    vs calais eco
    Sep 2006
    Disney land!
    im in the same boat mate and from what ive been told the crank should be fine! i think the only diference betwen the vl turbo crank and the n/a crank is that the turbo has bigger counter balance bearings or something like that (dont quote me not 100% sure) but as for strength just get it balanced and nitrided for extra strength and you might want to put a new set of pistons on it to drop the compresion and improve strenght hope this helps mate good luck!
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    good set of forged pistons to suite, drop the compression and the bottem end is pretty much ready to go if u just want to run a mild sorta setup
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    the only differnces between an n/a and turbo motor is, compression,cam,oil pump, inlet manifold, ecu, injectors and the fact it has a turbo on it
    VN Executive V8
    Jan 2007
    If your pulling it down you may as well put some good gear into it.The RB30 block is good for around 700 HP. How far you take the rest of the engine is up to your wallet.
    VN V6 Manual
    Mar 2007
    The South
    Stock compression rb30 will take about 9psi before you get detonation, with a T3/4 turbo and massive front mount controlled with a wolf3d... lowering the compression is the go, getting a stocker rb30et exhaust manifold and aftermarket turbo with VLt ecu and turbo injectors. You can turbo those engines for very cheap.
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    VN Commodore
    Feb 2006
    make sure ya use the NA inlet manifold. they flow better than the turbo ones. the turbo ones are of an rb20det as far as i know. they have very un even runners. where the NA manifolds are fairly even
    VN Commodore
    Feb 2006
    also i did read something about how NA motors don't have the oil feed there. there was something said about series 2 motors have the oil feed there but blocked off. if not just tap into your oil switch. not 100% sure on this but i thought i would let you know anyway, incase it is true..
    VP Executive R-spec
    Jan 2005
    I've read that the rod bolts are different (and the pistons for the lower compression) apart from that they are the same. Like Defa is saying the series 2 VL came allready tapped and ready to go
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    VL Calais Turbo
    Apr 2007
    Quote Originally Posted by pr0n View Post
    what does NA mean?
    Naturally Aspirated not sure of spelling!
    vl turbo
    Mar 2006
    1 of my mates got 201rwkw 13psi major hi-flow t3 2 1/2 inch exhaust standard computer and injectors na manual gearbox with a crushed standard reg to up the fuel pressure he maxed everything out and had another mate of mine with 196rwkw same set up but with a t4 turbo both converted na to turbo and thrashed every day
    87 vl berlina
    Aug 2009
    taranaki
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by tubular2 View Post
    hey blownbt1 what does crushed reg to up fuel pressure mean? cheers
    It means dodgey so dont even bother asking nice dig by the way
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  15. #15
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    If the engines currently in good running order ,just slap the turbo on and dont run stupid amounts of boost..Put a big cooler on it to help prevent pinging,run 98 octane fuel and nock your timing back to 10 degrees BTDC.I know people who have thrown turbo's on 400,000km n/a engines and run 15psi all day every day without a drama for a years..
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
  16. #16
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
  17. #17
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    no comment. wrong thread.
  18. #18
    govlgo is offline cant kill n/a motor
    vl rb30et
    Oct 2009
    WEST
    my stock vl has been running 10psi off a n/a block with a td05 turbo cant kill it!!! shes a beast turbo for about a year now wont die!!! standerd everything just with a turbo bolted to the side of a n/a rb30e block. made a massive upgrade in power.
  19. #19
    vl rb30et
    Oct 2009
    WEST
    take one for the team weld the wast gate closed and tell us how much psi she took before it poohed its self haha
LinkBacks (?)
  1. 10-04-2008, 01:11 PM
  1. Turbo conversion Q&A
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-02-2008, 04:06 PM
  2. Any1 Done a VL Turbo Conversion
    By BigDaz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-01-2006, 08:30 PM
  3. FS CRS trimatic to turbo trans conversion kit
    By Cane_It in forum Parts And Other Items For Sale
    Last Post: 19-11-2005, 06:07 PM
