Results 1 to 2 of 2
Thread: Webber carb on Red 173
    VN V6 Manual
    Mar 2007
    The South
    Default Webber carb on Red 173
    Just been doing a bit of research on this because the Stromberg definately has to go, and until now I have only heard rumours about fitting the webbers from rubbish dump cars on the old sixes. Basically I just wanted to make a list on what I would need and what would be the best way to go about doing a conversion.
    So far I gather I'll need...
    Webber carb "32/36 DGV"
    Redline adaptor plate
    Manifold - Seems the stock stromberg manifold would be too small... perhaps a 350 Holley redline/lynx manifold with the adaptor plate fitted?
    Haven't seen the webber carbs enough to remember what hoses and vacuum lines and fuel lines run to it, but Im running an electronic fuel pump to it which is running on the Stromberg right now. I also heard about problems at 3k rpm+ and WOT with the accelerator cable hitting the adaptor plate or manifold. I have a dremel here so I could work around these things with a bit of grinding. Just good to know what to expect.
    Things I'm concerned about is problems with the engine idling and running because of manifold vacuum lines and larger spacing in the manifold messing with mixtures etc... however Im sure it will be all ok =)
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    VX11
    Mar 2007
    Hi, I had a torana with a 202,ACl Flat tops,yellow terra head and heatseeker stage 3 cam. Had a 2 barrell holly on it and found it to be crap.Fitted a twin stromie setup. The power was strong right through to 6000 rpm with good low to mid range power.
  1. Webber at Monaco
    By Bax in forum Motorsport
    Last Post: 14-06-2006, 04:35 PM
  2. 202 Webber project
    By vkberlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-02-2006, 10:26 PM
  3. webber installation?
    By kooloo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-10-2005, 07:03 PM
  4. Varijet carb adaptor plate for XE carb
    By trophy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:53 PM
  5. Webber Overdrive
    By VSTrev in forum Motorsport
    Last Post: 27-02-2005, 01:08 PM
