Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: who has a hot 6??
    hsvtj's Avatar
    hsvtj is offline now cruising..
    VK wagon, VS Statesman 5.0
    Jul 2005
    Berwick
    Default who has a hot 6??
    it seems there are more people around with hot/turbo/supercharged 202s than i thought. ive seen a few of the guys on here with some nice old 6's.
    who else has a hot 6 here? im interested in seeing who else has taken that path in their early commodore??
    VT feature car, WRX STI WAGON
    Aug 2006
    im gathering most dont post them up cos they are a pretty basic old engine to start with....
    most dont get unreal power from them
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I've done a bit of work to my 173....I wouldn't call it a hot 6, but maybe a mild 6.
    - 173 (blue motor) bored out 130thou to a 186
    - Flat top pistons
    - Crow cam
    - Crow performance valve springs
    - JP straight cut timing gears
    - JP oil pump
    - High compression 173 head, shaved 10thou for that little bit extra compression
    - Fully balanced bottom end
    - ACL Monotorque gaskets
    - ACL rings
    - New waterpump/fuel pump/lifters/alternator/starter
    - Chrome rocker cover/side plates/oil pump cover/thermostat housing
    - Bright yellow paint!
    That's roughly bout it.
    VK 6CYL 5SP
    Nov 2007
    NORTHSIDE BRISBANE
    Nice one, Just take off the varajet lol
    What fun is having a licence and following ALL the rules?
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Looks good danny! I had a nitrous fed 202 at one stage. Gave a few decent v8's a scare but at the end of the day performance is really with the v8 motor. The 202 blocks can only handle about 320rwkw before they break. They are a good little motor though! I have a soft spot for them!
    hsvtj's Avatar
    Jul 2005
    Berwick
    Quote Originally Posted by CHEETR View Post
    well ive been hunting round and theres a few guys still getting some power that well and truely rivals the v6 and even the 5.0
    i know most ppl dont like em, thats fine.
    Quote Originally Posted by Dan355 View Post
    yeah i agree looks pretty cool!
    well obviously the v8 will always be better off in the long run, but 320rwkw is still plenty of fun lol. i just like the idea of doing something different, and seeing the look on V8 drivers faces when my old 'no good' 202 pulls away
    DANNY8's Avatar
    Apr 2004
    The varajet will be staying on there for a while....it's only a few days old :P
    I mainly did mine up as a learning curve. Next time will definitely be a V8 (well sometime in the near future). I've spent close to $2500 on the old 173, which could of easilly paid for a whole EFI 5.0L conversion with change left over.....which obviously would of been the better choice lol.
    bolby's Avatar
    bolby is offline werd
    VH SLE 202 turbo
    Apr 2006
    endeavour hills, melburn y0
    i agree that money can def. be better spent and that the 202 is now power house
    but thats only in n/a form. with a decent combo and forced induction, its a different story. thers a few ppl pushing more than 300rwkw out of them, but that is where the block decides to call it quits, obviously nto all blocks though
    its a great engine to start with in terms of first modified car and what not, so dont dicsount that just yet.
    theyre not all bad
    hsvtj's Avatar
    Jul 2005
    Berwick
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    grout filled block + bmw rods and pistons = bullet proof
    + jzed head
    + big turbo or supercharger
    = winner
    Dan355's Avatar
    May 2006
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Dose Pipe View Post
    + jzed head
    = winner
    Nothing is bullet proof mate you got the rods do ya ?
    Dan355's Avatar
    May 2006
    He knows its not lol. A mate of ours just threw a rod through the side of his 202 block and that was grout filled ect ect. As you said nothing is bullet proof! Its just a matter of finding the most power and reliability which is hard when ur running 15+ psi on a 20+ yr old block.
    vz wagon
    Aug 2006
    Wild west of Melb
    Was it the bmw rod ? my mate had that set up in his speedway car bmw rods grout filled and on methanol his first night in it he left it in first spun it upwards of 8000 rpm the dizzy **** itself thats why it stoped when the engine was pulled down all that was wrong inside it was the crank it had cracks you could see in it so saved on the xray there lol.
  15. #15
    Sep 2005
    that was a half grout filled block and a starfire rod
    and it was also more like 25psi
  16. #16
    1983 VH SL 3.3 Litre 5 speed, 2002 VY Executive
    Feb 2007
    Burnie, Tasmania
    Hmm Repco Engine would be a good base to build on, as most are either reconditioned or new. my Blue 202 is pretty mild, only has extractors, hot cam and a 250 webber.
    F.O.R.D
    Forget Out Running Datsuns
  17. #17
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    I have an injected VK that was running a Milld cam 040 bores and extractors, i have since pulled that out and started with a fresh Block, here is the list so far.
    • 020 Bores using ACL low compression "unleaded pistons"
    • Diesel quality hardened valve seats
    • The bare minimum shaved of both the head and block faces
    • Crane cams valve locks
    • Roller rockers
    • Manely hardned pushrods and guide plates
    • postive seal valve stem seal
    • Secret cam grind developed with my local cam grinder
    • 020/010 ground crank
    • closed, honed and shortened Starfire conrods
    • HM Header extractors
    • 3" mild steel single muffler exhaust
    • Toyota SC14 Supercharger (yet to be mounted)
    • Toyota GT4 water to air intercooler
    • malpassi rising rate fuel pressure reg.
    • Std elec Dizzy
    • Accel super coil
    • 10mm leads
    • JP hi flow oil pump
    • JP adjustable alloy timing set
    on paper, i have worked out that it should run about 7.5:1 compression, into which i am hoping to feed 12pound of boost and hopefully see around 150kw.
    well at least thats the list so far
    In the pipeline for the futre
    Motec or microtech ECU with conversion to Fully sequential injection and 6 coil ignition and MAP sensor load instead of AFM
    thats all running into a Exedy 150% clutch to a Toyota Steel case 5 speed then a VH SS brock 10 Salisbury LSD
  18. #18
    DANNY8's Avatar
    Apr 2004
    So ur still running the standard ECU then? I didn't think ya could do much to the motor with the standard ECU as it can't be tuned....so ya really gotta get a decent computer b4 ya start playin around with one. I know most of the gear on ur list prolly wouldn't effect it, but still just curious.
    That's the only thing stopping us from chuckin a fat cam and valve spring combo in PEAKN6, thought we would of had trouble as it can't be tuned properly.
  19. #19
    bolby's Avatar
    VH SLE 202 turbo
    Apr 2006
    202injceted thats a nice build up!
    it would almost be a shame not to put a turbo on that
    the sc14 should provide 10-12psi but a motor like that would cope with upto 20psi!
    i should have mine started back up again after doing some smoothing in the bay but will be without the turbo so will be running 7.5:1 comp through a powerglide lol
    fun stuff!
    good to see theres still a few ppl playing the the old 6
  20. #20
    boomnvn's Avatar
    boomnvn is offline SOLDER, NO CRIMP.
    VT Exec S1 V6
    Oct 2006
    Croydon
    my VC wagon runs a black carby 202 with a mild cam and holley 350, and made 75rwkw on the dynomotive dyno dynamics dyno. i'm planning a CRS supercharger kit just to be a bit different, as everyone else is going turbs... and whoever says a 202 can't make power, get ur head checked. and check out my mate sniffy's pink torana coupe (u might have seen him on the princess hwy, dandenong or @ heathcote), he's a midget so he's a bit easy to miss, but he's got a 202 efi turbo setup i his torana and runs 10.71 @ 125mph... not bad eh?
    CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
  21. #21
    Apr 2004
    what are the specs of your mates torana boomnvn.. sounds interesting I wouldnt mind seeing some pics too.
  22. #22
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    G'day mate, I hav a red 202, with XU-1 spec. 179 Head stg 4 and it had big vavles, 040"thou flat top pistons with chrome rings, 179 steel crank, hi volume oil pump, Cam 35/75 xu-1, electronic dizzy,Redline Torker 2 manifold, 500 Holley, Pacemaker's extractor's, hi comp starter.She used 2 pull 130km/h in second gear. Now, we are think change the cam, and carby, to get more power. This was in the vh commo.
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
  23. #23
    83 VH commodore 2.85ltr
    Mar 2008
    i live in Darwin N.t
    Default Help
    i have a blue stock 202 and im wanting to improve horsepower ??
    can u put a turbo system in them?
  24. #24
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    yes quite easly there is a white vc { i think but not 100% } with a hairdryer on here check the my ride section
    Eureka styles!
  25. #25
    VS BT1
    Apr 2006
    [QUOTE=DANNY8;687100]I've done a bit of work to my 173....I wouldn't call it a hot 6, but maybe a mild 6.
    Why would you bother with a 173?????
