Results 1 to 8 of 8
Thread: carb heat
    vh wagon/efi 202 off road car
    Apr 2008
    Default carb heat
    Has anyone else had issues with the varijet after installing headers/extractors? flat spots etc from the removal of the standard carb heat setup
    5LT VS series 3 UTE manual
    May 2008
    this is a 6cyl yes. did u remove the carby the base gasket may be leaking also did u replace all the hoses corectly. some times it could be a split hose they look fine but on closer inspection domage has been done on removal.
    Apr 2008
    All that was done was the installation of headers,
    The standard manifold has a part of it that bolts to the bottom of the inlet manifold to provide heat to aid fuel vapourisation and emmissions.
    The carb has been overhauled, the guys that overhauled it say the problems (flat spot, gutless) are caused by lack of heat, I am interested to see how other people have gotten round this problem.
    An XE weber is going on in a few months which will get rid of this problem but thats months away,
    I am wondering how all the other people with headers and varijets have got around this problem
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    with my experiance of the varajet carby they all end up getting a flatspot in them, even ones with the standard exhaust system, once they get old the best thing to do with that carb is throw it out the door
    May 2008
    is it a problem all the time or only when you drive it first thing. within bout 2 min driving time dont matter if you got heat risers attached or not . it grts pretty fugin hot. did u have the carby overhauled before or after fitment of rackies.
    Apr 2008
    the carb was overhauled but the problem turned out to be the mechanical advance was too stiff.
    old time 202 lad found it
    '87 VL Calais with L67
    Aug 2007
    get a holley 350. that kicks anus when youve got headers on any 202
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    VP Executive R-spec
    Jan 2005
    I just bought a copy of the factory Varijet manual, horay . That's the only thing that needs a bit of work on my SLE, then I'm going for a cruise
  1. 202 carb heat
    By newtownbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-06-2008, 05:42 PM
  2. Which Carb??
    By vb_commie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2007, 05:43 PM
  3. 202 carb
    By VH_Commodore_Wagon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 07:20 PM
  4. Me and my Carb
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 09:16 PM
  5. Varijet carb adaptor plate for XE carb
    By trophy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:53 PM
