Results 1 to 25 of 25
Thread: What can i do to make my VL more economical?
    LX SL sedan
    Dec 2008
    Galwer SA
    Default What can i do to make my VL more economical?
    I got an auto VL wagon with just a standard 6 in it. What can i do to make it use less fuel?
    '87 VL Calais with L67
    Aug 2007
    pump up your tyres and take all the useless crap out of it. don't hoon. thats about all i can think of
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    LX SL sedan
    Dec 2008
    Galwer SA
    I was thinking of more what engine mods i could do. I have bashed out cats and highflow muffler. I think a pod filter would help a little bit. If i advanced the timing a little bit would that make much difference?
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Extractors will help a little with fuel economy. Make sure your oxygen sensor is working properly because it will drink fuel if the oxy sensor doesn't work. Make sure your temp sensor is working properly and your thermostat closes off when the engine is cold so the engine warms up quickly. Give it a tune up so it is running nice and smoothe and change the fuel filter.
    BLOWN R8's Avatar
    BLOWN R8 is offline WHISTLE BY HARROP
    BLOWN R8 LOO, LC 406, HT PREM, HQ COUPE, VLT, VXSS
    Aug 2008
    WESTSIDE SA
    vy2 clubsport
    Feb 2008
    adelaide
    LX SL sedan
    Dec 2008
    Galwer SA
    thanks for the real reply tree cutter. How do i check if my oxy sensor to see if its working properly?
    Also, i have heard from my mate who is a qualified mechanic that by putting a hotter thermostat in the engine (thermostat that opens up later) it will use less fuel by tricking the computer into thinking that its running lean or something. Is that right?
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Don't bother with the thermostat crap, if you want it running lean get it tuned lean. That's what I did in my VN and it uses a fair bit less fuel now.
    Also, honestly, bashed out catalytic converter? Why? There is no reason for this, you're just spewing all sorts of toxic **** out your exhaust pipe.
    WTB: mulberry VN interior parts
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Not worth the hassle with the thermo.
    Keep it serviced as well. Good clean plugs, good oil, clean filters etc will help.
    Even running premium will help.
    And agreed with the above. Replace your cat, if it's just an n/a put a standard cat on there, wouldn't even worry about the hiflow.
    LX SL sedan
    Dec 2008
    Galwer SA
    why isnt it worth the hassle with the thermostat? it will make it use less fuel right? after all, its only two bolts...
    LX SL sedan
    Dec 2008
    Galwer SA
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    check your manual, it should say in there
    -do a service 1st...
    -replace your cat because its not doing anything besides spitting out fumes that should be filtered (will stop your car sounding tinny aswell)
    -CAI
    -tune?
    and exactly how many km's are you getting to a tank? so people can tell you if thats normal or crap
  15. #15
    LX SL sedan
    Dec 2008
    Galwer SA
    i dont know what the km are exactly but i think it would around 250 - 300km from a wagon tank (62 liters i think)
  16. #16
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lol that's crap
    definitely get checking those sensors... look it up, there's a few how-tos for VL sensors around here and the SC forum.
    Sam
  17. #17
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    i was getting avg 600km a tank in my berlina, and a few times over 600
    it was manual, i drive like a granny
    full exhaust, high flow cat, extractor etc
    CAI under the guard, k&n panel filter, custom intake piping
    every sensor was new, temp sensor, o2 sensor, CAS always made sure no errors on comp
    timing was on mark, not advanced, 95 ron fuel
    new leads, plugs and service every 5000km
    thats bassically how i had my econemy so good, but i was changing gears at 1200rpm lol this is my normal driving style but when didnt cause any labouring on the motor
    on flat cruisng at 50km/h in 5th
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  18. #18
    VT spac super6
    Nov 2008
    Riverton sa
    i was getting 450-600km from a tank.. this was country driving but still driving it fairly hard
    5 speed manual
    extractors, straight into single muffler
    19degrees advanced timing
    CAI (under guard to bumper)
    you CAN adjust fuel/air mixture yourself, remove the kick panel to reveal the computer and start the engine... the led's should flash together.. if not on the AFM theres a small round cap near the plug, pry it out and turn the screw inside say 1/8turn at a time until the leds flash together...
  19. #19
    Oct 2005
    or you set it to factory
    multi meter, prod in plug cable 6 and 1
    engine off and read ohms, adjust it till it reads 362ohm (think thats factory)
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  20. #20
    VT spac super6
    Nov 2008
    Riverton sa
  21. #21
    LX SL sedan
    Dec 2008
    Galwer SA
    took the passenger kick panel off and the LEDs just both stay on all the time and dont flash. What does this mean? (one was red and one was green btw)
  22. #22
    VR Wagon
    Oct 2008
    Central Coast, NSW
    As everyone has said.. Service it check all your sensors and drive with a lighter right foot. I am getting 150km out of 17 litres in my VC with a standard 202 with local driving and thats as good as my old gemini.
  23. #23
    wh v6 statesman
    Apr 2009
    mornington peninsula
    Quote Originally Posted by 202lx View Post
    lol thats almost as bad as what mine was getting to a tank but mine had serious issues at cold start and black smoke out the exhaust but i re tuned the airflow meter and it running alot better but saying that i only tuned it till it sounded right i still got to do it properly with a multimeter and that was after i changed all the sensors.
  24. #24
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by JoshSvc View Post
    I use to get 280-300k "probley even a little more" out of 20 liters with my old vc, rebuilding the carby plus timing helps with a good service to the engine including "auto" gearbox.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  25. #25
    Goon's Avatar
    Feb 2006
    GC. QLD
    I can get 400k easy on half a tank "VL" from a trip to cairns to townsville, giving me a quater to go when i get there.. be shes running rich atm, but thats about to be fixed!
    I did over 800k or around that mark with a full tank "While running rich" from mackay to cairns" thats with hills too!!!
  1. how can i make my VX better?
    By tehMaz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2011, 02:30 AM
  2. How can I make my car low?
    By Aaronthestig in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-08-2008, 10:55 PM
  3. Replies: 0
    Last Post: 22-10-2007, 12:13 PM
  4. How to make MP3 cd?
    By coolvxss in forum The Pub
    Last Post: 04-11-2006, 10:38 PM
  5. Need to make my ride more fuel economical
    By vyaw2003 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2005, 11:31 AM
